HeadLight PROBLEMS HELP !
Okkkkkkk so...... I seem to have a bit of a problem with my drivers side headlight and fog light being out..... fog light went out first then the head light........ i checked the filiment on the bulb of the headlight and its fine..... (getting to the headlight is a P.I.T.A. by the way) anyhow..... im thinking that it could be a fuse. I looked both by the battery and under the sterring wheel fuse boxes and all of them are intact. Is there something that I am missing??? There seems to be ALOT of different fuses that are missing that I cant seem to find ie"headlight,a/c compressor,ect" Can someone please point me into the right direction??? THANKS A BUNCH ! !
BTW........ I have the 9012 halogens :) |
You may want to make sure that the contacts inside the plug are touching the contacts on the bulb. To test if it is the bulb, either grab the bulb from the passenger side or the original bulb and plug it in and test the lights. A worst case scenario would be that the wiring harness is fried due to a higher watt bulb
Not sure what is in the fuse box under the beauty cover on the passenger side of the engine bay. May want to check there too.
CM |
© 2024 MH Sub I, LLC dba Internet Brands
