RacingLine endlinks bushings
Hey guys, had a question about the RacingLine endlinks. I not too long ago installed a Stillen FSTB and a Progress RSB and i would like to get the RacingLine endlinks to install on the Progress RSB seeing that Progress does not make their own endlinks. Right now the stock endlinks work fine, but a number of max.org members have advice me to change them and that will also help with the performance.
I was talking to Brian from Cattman and he said that the RacingLine endlinks bushings usually burst after a while. Can anyone confirm this?
Kamski
Fixed
Bushing failure on th V1 style endlink was a result of 2 issues, (1) the maxima being a heavier car than what the endlinks were originally designed for, and (2) I had switched suppliers who had quality issues. Depending on the time frame when the V1`s were bought will determine if there are potential bushing failures.
V2 rear bushings are custom graphite empregnated poly bushings with metal inserts made by energy suspension......They will not fail!
When are the front endlinks going to be resupplied and will they have the same bushings as the rears? My front wheel is still clunking over little bumps and its got to be the end links!?!?!?!?
well i can tell you this much...my V1s completely blew out and broke for that matter...buh with the same driving style...these V2s are deisel as hell. no problem and crazy responsiveness...still in great condidtion to this very day...
Nah, I just replaced the OEM struts with new Monroe SensaTrac struts. On smooth roads its great but whenever I hit holes in the road it gives that BUMP noise from the right front wheel. It doesn't usually do it on hump in the road, usually when the wheel freefalls from broken pavement then once it hits bottom and starts to rebound I get the BUMP noise. I figure its the endlink that has too much play in it and then it allows the swaybar to move freely and wiggle.
What brand are they? I dont want OEM b/c they just suck. Did you have the same type of sound and loose feeling in the suspension?
knight_yyz
11-01-2015 01:34 PM
