removing pinstripe/maxima stickers on side of '08
Old 06-14-2008, 12:42 PM
tmas74's Avatar
Hey everyone,
Just curious... If I wanted to remove these (along w/ the dealership name on the back)... whats the best way to do it? Will they peel off relatively easy? Probably not. What should be used to get off the residue?
tmas74 is offline
Old 06-14-2008, 01:04 PM
MAXIN' ON
redls1's Avatar
I took mine off the first weeK I had the car and everything came off easy. I just started at one end and pulled.
redls1 is offline
Old 06-14-2008, 01:09 PM
tmas74's Avatar
did you have any residue on the car after?? if so, what did you use to get it off?
tmas74 is offline
Old 06-14-2008, 01:56 PM
jasba's Avatar
No residue, just peel them off slowly. They come off easily.
jasba is offline
Old 06-14-2008, 02:52 PM
STARR's Avatar
Park it in the sun for a couple hours depending how hot it is and then just peal them off, any sticky residue will come off with some cleaner wax
STARR is offline
Old 06-14-2008, 05:37 PM
WINTERFAUST's Avatar
you can buy a 3m eraser wheel it fits on the end of a cordless drill and can be bought from most parts trucks (snap on or mac) or do the peel method followed with 3m adhesive remover followed with a nice coat of wax either way
WINTERFAUST is offline
Old 06-14-2008, 05:42 PM
Drockb418's Avatar
use a hair dryer or keep it in the sun for a long time to get it warm not burning hot and it should be good to go
Drockb418 is offline
Old 06-14-2008, 05:56 PM
roll4life's Avatar
roll4life is offline
Old 06-14-2008, 09:22 PM
2LEET4U's Avatar
I peeled mine off and had major residue.... I have an 05 Max so it was on for 2 years.... so the sticker was old...
i guess it all depends on how old your maxima is.
When removing the stripe, i noticed a tan line left from the sticker. I had to hire a professional detailer who color sanded my car and removed the line. It was pretty bad.
So if you do decide to take off your stripe, be careful....
2LEET4U is offline
Old 06-16-2008, 10:07 PM
Yankeeblue04's Avatar
so its easy to take off the pin stripe, what about the emblems? If they are removed would there be holes that would need to be filled?
Yankeeblue04 is offline
Old 06-17-2008, 03:45 PM
SteadyC's Avatar
If you have no expierence debadging or removing pinstriping #1 take it slow you dont want to make a costly mistake. I know that the maxima and 3.5se badge don't leave holes but will leave some holograming unless polished to perfection. (real polish= somewhat abrasive) If i had to give advise find a good detailer (like me) and pay them $50 to do it correctly. If you really want to do it PM me I could give you some pointers. P.S. I am not aware of the actual nissan symbol as I have the lip spoiler and left m ine on. others chime in
SteadyC is offline
Old 06-17-2008, 10:35 PM
Thanks, well the pinstripe came off with no problem and no residue.. Apparantly this was done aftermarket cause the lines was not straight at all. I'm going to wait to debadge it. Damn the car looks alot better without that grey pinstripe
Old 06-19-2008, 08:05 AM
DCUnited10's Avatar
be careful!
DCUnited10 is offline
Old 07-26-2009, 05:16 AM
buldgg09's Avatar
so i have a problem right now with removing another pinstripe under the grey ones,,,i have used many goo gones ect. is the 3m wheel the best thing to do?
buldgg09 is offline
Old 07-26-2009, 06:13 AM
SteadyC's Avatar
Nine times out of ten the 3m wheel will scratch your paint. Use a hairdryer or heatgun to warm it up and slowly peel it off. Make sure you dont over heat as that could also do damage. Also 3m adhesive remover is an awesome product for getting them off, it will penetrate the pinstripe and make it easy to pull off. Good luck!
SteadyC is offline
Old 07-26-2009, 11:45 AM
This Space for Rent
Domestic Violence's Avatar
If you only have adhesive left, use a claybar
Domestic Violence is offline
Old 07-27-2009, 05:27 AM
Staggered357's Avatar
or an alcohol pad works surprisingly well..
Staggered357 is offline
The Frye
09-02-2021 11:03 AM
03-12-2020 12:06 AM
The Wizard
24
10-01-2015 08:47 PM
Colossus
09-09-2015 05:46 AM
FanaticMadMax
09-04-2015 02:45 PM
Quick Reply: removing pinstripe/maxima stickers on side of '08
