so where did the sticky for headlight aiming go ??
I clicked on it and all that came up was a story of a dude's wife cheating on him with all the lawyers she works with .......
Who can help me adjust my headlights ?!?!?!
nope, still not working at all. when i open the thread this is the address i get :
http://forums.maxima.org/3786510-post35.html
http://forums.maxima.org/6th-generat...ered-cars.html
Post number 20 has a better picture.
http://forums.maxima.org/6th-generat...-change-2.html
All the pictures are gone. If you have a copy of the fsm it shows in there. From another post.
Ahhh ha! I found the vertical adjuster for the drivers side headlight!! I had to take out the wheel liner to get to it. Removing it was relatively easy. Just a lot of little fasteners to remove.
In the picture you can see that it is above the main headlight reflector assembly. It is indicated with a red arrow in the picture. There is a similar screw on the bottom of the assemlby, which I would immagine is for the horizontal adjustment. There is a plastic cover on it, so I wasn't able to test it.
Access to the horizontal adjustment is easiest from the wheel well. Though with the right tools you could get in from the top and avoid all of that. If you had a ratchet that only needed a few degrees of turning to work that would be perfect. The adjuster works either with a phillips bit, or a 10mm socket. The socket would be best since it won't strip as easily as the screw.
Tightening it, or turning it clockwise raises the beam. Counter clockwise lowers the beam.
So now, with a little luck my headlights will be adjusted properly!
http://forums.maxima.org/6th-generat...-lowering.html
here are more pictures. There is a link in there also that the old thread show thread didnt work
doctorpullit
10-28-2019 10:58 PM
trsandrew
04-08-2016 06:45 PM
knight_yyz
11-01-2015 01:34 PM
trsandrew
10-25-2015 02:47 PM
