which cams???
which cams fix our 6 gens more specific my auto max 2006 thanks for the help.
i heard that the 350z cams fit our cars is this true??? |
I belive so, they are the same engines.
i talked to a shop that sells cams and they said there are 3 diffrent kinds of VQ35's......
Originally Posted by whiteSE
(Post 6690967)
do you want performance based cams, stock cams what?
this thread is very vague but I can think of about a dozen cams out there for the 3.5s and they all fit. |
Could it be the normal DE, then the one from the '06 Z with the Uprev(7k rpm redline), and third one is the HR?
If so, ours are the first type of VQ35 with 6600rpm redline. |
Originally Posted by I VIK I
(Post 6691012)
I stand corrected.
WELL IM LOOKING FOR PERFORMANCE CAMS... HAVE U SEEN THE Brian Crower Stage 3 cams on the 350z on youtube.com??? http://www.youtube.com/watch?v=22_KmWEEGrk
listen to dattt |
Originally Posted by drzcrazychulo4u
(Post 6691198)
listen to dattt Stage 3 is waaay more than you would need for an NA Maxima. You will probably lose all low end power and only make power past 5500rpm. |
You may get more help in the All Motor section. There are also quite a few stickies in there regarding cams.
(Post 6691198)
listen to dattt As far as HR and uprev there have been guys who have done them but you should read up on it cause you need to be of certain bolts to use. KRRZ350 made a discovery about it. Lastly, the S1 knockoffs are the best your and cheapest bet really and are well rounded and not too aggressive |
Cams should be the last thing you do on a n/a car. Do all the other bolt-ons before you take the leap on paying as much for labor as the cams...exaggeration, but close to it.
To the Opening Poster... what mods do you have done LOL...
Originally Posted by !PrjctMax!
(Post 6693846)
i have magnaflow exhaust, nismo cai, ssim, throttle body spacers, grounding kit and dats about it..... im working on getting TS
(Post 6693978)
And seeing how deus comes back with results on the 3" single exhaust. |
im an auto and wats big bore???
(Post 6694000)
isant that like porting and gutting the intake manifold??
(Post 6694184)
so u have just a throttle body spacer... not the whole kit?? |
/thread
:mrgone: |
you looking for an expensive install on cams.. your only bet is the jdm cams or s1 knockoffs like Dave said.
Anything after that your looking at upgrading valve train and head bolts, springs , retainers.. This should be last of your mods , looking into a ECU or some sort before you start knocking internally |
no well i have the whole kit installed
Originally Posted by NiZMo1o1
(Post 6694452)
springs |
Seems to me all cams do is rob your bottom end and give it to the top end. Talk about rob Peter to pay Paul. Perhaps if I saw a cam install with a AFC tune would change my mind.
It's more than an ' AFC tune'... more like a CVTC&IGN&AFC 'AFR' 'tune' that makes a difference...IMO...
Cams are overrated...unless you understand them, (as in peak lift / duration and how that value does not make the 'ultimate' difference) |
can youbolt on a pathfinder tb cause i know theyre big
Sure.
how about a VH45 TB to a 350z Plenum :hide:
© 2024 MH Sub I, LLC dba Internet Brands
