Oil burning smell
Oil burning smell
Guys I believe I have a small oil leak that could be my valve covers. It started after my last oil change. How much am I looking at to change out the seals? I am not taking it to the dealership. I have about 120kmiles
im not sure considering many different mechanics have different service hour prices plus they have to get to covers and look at them and make sure its them and not something else so i bet after everything it can be pretty expensive
yep. take it to a local shop you trust or have gone to before..usually they will at least take a look under the hood to see where the oil is coming from depending on how busy the mechanics are, etc. then they'll give you a written estimate if they want your buisness bad enough.
Back to the subject. If it is a valve cover gasket issue then you should be able to DIY. I haven't done it on this engine but I have on my pathfinder and if I can do it on that thing then you should be able to do it on this car. I will look after work but if it is accessible you can pick up gaskets at your local shop or get them online. there are some gaskets that last a real long time and I am pretty sure that nissan uses the longer lasting gaskets. install could take a while depending on obsticles. I would assess the situation see if you think you can do it and estimate how long you think it might take, and then double that time and make sure you have at least that much time available. Also keep in mind if you use a chiltons it may not be exact so keep a computer close by. You also know that you can go to your local nissan dealership and request to look at the service manual. never hurts. My dealership even made me copies of pages when I needed them.
litch
123
01-04-2024 07:01 PM
06-06-2017 02:01 PM
