5th gen parts fit 6th gen?
hey guys i'm pretty sure it's been asked and discussed and i've searched but found nothing. will 5th gen performance parts fit 6th gen? for example, headers? thanks in advance! :D
Originally Posted by silverbeast2004
(Post 6813905)
yea i was thinking the same thing. But if i'm not mistakened, the 5th gen has the same engine, or is very similar to the 6th gen engine.
i think the 5.5 gens technically would bolt up to the 6th gens but i think i remember cattman having trouble with clearance issues and cel's on the 6th gens so i bet they arent swappable
Originally Posted by Feldman
(Post 6813961)
So then it's basically just the clearance. And can't we always get an egr port put on so it fits?
You'd be better off asking the fifth genners.
There's also a performance/motor section. |
You can't use 5.5 Gen headers on a 6th Gen or Alti, at least, not the way they come from the manufacturers. Take a look under each and you will see why.
4th, 5th, and 5.5 Gen Maximas have a subframe piece commonly referred to around here as a cross member while the 6th Gens have a cradle looking subframe. The y-pipes therefore have to be completely different. You could use the headers with a custom y-pipe, but I'm not sure how cost effective that would be as opposed to just buying a set from Cattman. Even then I'm not sure the angle at which the collectors from each bank comes down would work, because the headers are designed to go with a specific y-pipe. 5.5 Gen (Derrick2k2SE and mine): http://i11.photobucket.com/albums/a1...headers004.jpg http://i11.photobucket.com/albums/a1...s/DSCN4330.jpg 6th Gen (chernmax's): http://i16.photobucket.com/albums/b3...x/IMG_0195.jpg From here: http://forums.maxima.org/4189488-post131.html |
The headers LOOK similar in the pictures, but they are different. The main difference is still the y-pipe though.
Compare here: http://forums.maxima.org/5th-generat...es-4-38mb.html And this picture of Gen II Cattmans for the prev gens: http://i11.photobucket.com/albums/a1...s/DSCN3980.jpg Vs chern's picture of his old Hotshots here: http://i16.photobucket.com/albums/b3...x/IMG_0159.jpg You can see that the rear bank collector flange on the 6th Gen headers curves toward the front of the car while the 5.5 Gen header collector flanges point straight down, from what I can see from the pics. |
I would assume if the 5th gen headers did fit there'd be alot of us that would of had them along time ago and Cattman would not have taken the time to develop 6th gen headers....
Originally Posted by jsmithsole
(Post 6817130)
All good information...Thank's:bonk:
© 2024 MH Sub I, LLC dba Internet Brands
