Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   6th Generation Maxima (2004-2008) (https://maxima.org/forums/6th-generation-maxima-2004-2008-48/)
-   -   fubar'ed my rear tire :( (https://maxima.org/forums/6th-generation-maxima-2004-2008/584391-fubared-my-rear-tire.html)
AscendantMax Mar 4, 2009 11:54 AM
Sooo...does anyone know how the hell i managed to do this to my rear passenger tire?? i think it's rubbing onto something since my rear suspension is going bad, and the rear is squating pretty low. the cut goes almost completely around the tire. good thing i was driving on a local street and not on the freeway! there's no fingergap at all in the rear, and to my recollection, there used to be 3 or 4 when i drove her off the dealer's lot.
https://img.photobucket.com/albums/v...a/03042009.jpg
https://img.photobucket.com/albums/v...3042009002.jpg
https://img.photobucket.com/albums/v...3042009001.jpg
https://img.photobucket.com/albums/v...3042009003.jpg
vQmaxii Mar 4, 2009 12:00 PM
it could be the drop mayb..but dam thats crazy
it could be rubbing but on what?
Stormzusmc Mar 4, 2009 12:04 PM
****ty defective tire dry rot?
LILAZNSHAGGY09 Mar 4, 2009 12:10 PM
i say its the tire....
04LowLife Mar 4, 2009 12:32 PM
I had a tire do that also, mine was running low on air which made it fold over a little and it wore it out on the crease
baldo2104 Mar 4, 2009 12:41 PM
There were some cheap tires on my car when i bought it. After a couple of hours of spirited driving on some mountain roads the outer wall of 2 of my tires looked similar but did not blow completely. Hard driving on bad tires maybe?
fflint_18 Mar 4, 2009 12:59 PM
I doubt of it's the drop. You'd get the rub on the outside first.
Agree that it's probably a defect in the tire.
AscendantMax Mar 4, 2009 02:46 PM
i spent quite a bit on these tires too. still got some good thread life. they're bridgestone potenzas re960's.
tire pressure is still good. i checked about a week ago and they were all hovering around 32 psi.
Stormzusmc Mar 4, 2009 02:48 PM
how many miles on them? warranty?
AscendantMax Mar 4, 2009 02:55 PM
ummm...i would guesstimate around 15-20k on them.
NiZMo1o1 Mar 4, 2009 03:21 PM
low on air on teh tire...
CanadianMoFo Mar 4, 2009 03:33 PM
I had the same happen once on my first car. Chronic low air pressure in the tire causes the sidewall to bend too much and it weakens over time.
CM
Shoey1 Mar 4, 2009 03:47 PM
post some side view pics of your car so we can see how low it is.
AscendantMax Mar 4, 2009 04:35 PM
CM
will that affect both sides of the tire? the side facing outward still feels pretty stiff. i guess i'll take a look at it after i get the tire unmounted from the rim.
airMaxSL Mar 4, 2009 04:55 PM
that's crazy man, at least you weren't on the highway when this happened. would've been bad news.
[TexMex] Mar 4, 2009 07:30 PM
yeah..low air pressure..you probably got a nail or maybe just a slow leak somewhere and eventually when you ride on it underinflated for that long the sidewall heats up and deteriorates it to the point of a blowout. happens all the time at my work when rich soccer moms think its ok to ride on a low tire, then end up having a blowout on the freeway...
SmokinMaxSE Mar 4, 2009 07:52 PM
I thought when we lower our cars it could cause bad negative/positive camber? I know my camber is off bad. Anyway, bad camber causes the tire/tires to have more or less traction either on the side edges or center. Would it cause a tire to split? I've read that it can destroy tires and suspension very quickly.
Since I lowered the car I've had three bad tires. One original RSA in the front started with a small bubble and then split on the highway. Then two brand new General HP tires with less than 2K miles got huge bubbles on the inside in the rear of the car. Discovered while changing rims. Never had a car go through so many "bad tires" so I'd have to say its something with the car.
Good info...... http://www.nuttalltire.com/shop/compalign.htm
AscendantMax Mar 4, 2009 08:33 PM
what are you lowered on? i'm thinking of getting the kyb-gr2 struts/progress springs combo from an org sponsor.
SmokinMaxSE Mar 4, 2009 08:42 PM
Progress.
[TexMex] Mar 4, 2009 09:12 PM
the bubbles are from hitting stuff...impact bubbles causes the rubber to seperate from the bonding between the layers of rubber, and can cause a blowout pretty much at any time..poor alignment does not cause that but yes you get alignment wear like crazy if you dont get it adjusted back to spec after you lower the car
CanadianMoFo Mar 5, 2009 08:40 AM
I've got the same setup. Never had an issue with my 18" RSA's (OEM), 17" Goodyear Ultragrip (winters) or 19" Pilot PS2's.
CM
AscendantMax Mar 6, 2009 08:18 PM
CM
getting a bit off topic here, but how is the ride quality compared to stock? i know it'll be a bit stiffer, but am a little worried about it being TOO stiff.
klemenz Mar 6, 2009 08:24 PM
damn thats intense
STARR Mar 6, 2009 09:34 PM
Looks like a defective tire, if the other rear tire is fine then it's the actual tire, and if your tread wear is even then it's not low pressure, email the photos to bridgestone and you may have to either go to a bridgestone dealer or ship it to the head quarters.
You may be able to get some new rubber out of this
Staggered357 Mar 8, 2009 08:27 AM
yeah that definitely looks like a defective tire..dry rot...
