navi questions...please help thanks in advance
i have a 04 max with navi.....does anyone know what i need to do to play dvds on it?.......i seached the theads and no luck...is it possible????
Originally Posted by figueroa1357
(Post 7046997)
http://www.activetuning.com/products/multiple/RGB2+/ |
Originally Posted by trackstarz04
(Post 7047003)
yo thats crazy if u didnt do this yet let me know were you are and it can be done for half that if i need to ill find everything you need let me know p.m me
yea that's way too expensive for what you want to do. I will do some research for you. Don't waste your money on that. You could buy a whole new and better setup for that price.
Go to the audio section and post what your question is. There are alot of people who have come across this way before you. Try pming KPierson. He knows alot about this stuff. He sells the module for the 09 Maxima for this. I bet he can make you a plug and play for way cheaper. Let me know if you want more help on this.
http://www.tvandnav.com/index.asp?Pa...ROD&ProdID=187
my brother just put that on/in his 300C, works great, but you have to remove the entire dash and interior to plug it in behind the nav and run wires, especially a back up camera if that is the case, so 850 is not bad if that includes a back up camera and a warranty if anything goes wrong cause my brother just did his and it took him 8-9 hours start to finish |
would take less than an hour to do. 15 min to take the center pieces out. Should not take more than 45 to hook it up and close things up. very easy to get the whole center piece out. if you need wiring diagrams I can get them for you.
http://www.coderetard.com/2008/05/08...on-a-2008-g35/ here you go. this should work. Makes sense concidering. I will see if I can find the exact wires you need to find.
If it does work I just saved you 845 dollars and cost you 1 hours worth of work.
$850 = no!! Can be done much cheaper, just be patient and do research!!!
© 2024 MH Sub I, LLC dba Internet Brands
