How To Do The 07-08 Swap & What's Needed For Install
Hey Guys,
I've been getting a lot of e-mails lately on people asking how to do the 07-08 and what's needed/not needed for install. Here's What's needed for a complete install: 07-08 Headlights: Avg. $250-$500 (They make both HID headlights and Halogen so beware when buying) 07-08 Hood: Dealership Price $300-$400 (One of the hardest parts to find. If you can find one Grab it!) 07-08 Fog lights: Avg. $200 (One of the easier things to find, I have a pair if anyone needs it) 07-08 Fog light Covers : Avg $20 (These are the cheapest and easiest to get) 07-08 OEM Or Aftermarket Grille Oem Avg. $30 Aftermarket Avg. $200 07-08 Bumper Avg. $200 As you can see it can be a pricey modd. But WELL worth it. This and the led modd are by far the best two modds on my car. But now to clarify acouple of things people are worried about: Do you need to get the 07-08 Hood?: Yes/No. You can get yours modded but that will take the autobody place you go to at least 1-2 weeks. If you are trying to cut costs you can use your 04-06 hood but there will be gaps. I admit i drove around for about a month looking for a hood before I found one. It's almost like your car has slanted evil eyes. Do you need new fenders?: No way! I don't know who ever said that. But I keep getting asked and thats False information. Your stock 04-06 Fenders will work fine. No need to modd them. Are the headlights Plug and play?: Yes. They are completely plug and play. Only thing that won't work is your parking lights and your fogs. You'll have to re-wire them. Check the bottom of this thread for more info. How's the Bumper Bolt Up? It's directly the same fitment as the 04-06 bumper. Are all 07-08 headlights factory Xenon/HID?: No! Be careful what you buy and make sure they are HID if you want to upgrade or stay with HID fogs. You won't lose any lighting if you stay with HID. I highly recommend getting HID headlights if your converting. What's needed with these fogs?: The fogs are H11. I personally just bought an H11 6000k HID kit. I recommend searching for an H11 harness so if you want to convert back to stock or have your HID's plug and play you can do that. H11 harness is rather cheap depending on where you get it. How Do I Wire These Things up? Well, Lucky for you I made a thread and will include it for you lol. Check out my step by step method of fixing the parking light problem and fogs. Figure i'd write up a little "how to" on installing fogs from a 6thgen to a 6.5gen Step 1: Disconnect wiring harness from your headlights.... Cut back the black tape/tubing so you can see your color wires https://img385.imageshack.us/img385/9246/img0083mg0.jpg You see there's a black wire (Ground) and a white wire (Pos) for the fogs... Cut them from the harness... https://img178.imageshack.us/img178/3672/img0086dq8.jpg It's the corner part of the wiring harness.... now extend these wires about 2 feet down to you have some slack and test your fogs... NOTE: I actually had the connectors so it was easier for me to test... some of you might need to make your own harness or get H.I.D.'s to finish this step... https://img244.imageshack.us/img244/4158/img0089sg0.jpg once you did that your pretty much done... make sure your connections are good and sealed tight... also make sure you test everything out If you guys decide to get the 07/08 headlights you will notice once you plug it in to the stock harness the parking lights will not light up. In order to fix this you must take the original harness to the car and cut the ORANGE and THE RED N BLUE wire and splice them together. This will eliminate the problem and the parking light will function normally. If you guys are still having some problems. I helped out acouple of members do the install and I'm always down to help anyone else out. Just PM me. I live right on Long Island. Good luck! Hope this helps out some people |
Here you go guys....
The long awaited modd is almost fully complete SAY GOODBYE TO THE 6TH GEN FRONT! :ashamed: https://img167.imageshack.us/img167/7405/img0080as6.jpg THE OLD BUMPER! :ashamed: https://img243.imageshack.us/img243/5249/img0081xc2.jpg OH SH*T! My CAR'S BEEN JACKED! lol https://img243.imageshack.us/img243/8906/img0082fz7.jpg IT'S NIGHTTIME AND I'M STILL AT IT...WHAT A SHOCK LOL https://img244.imageshack.us/img244/651/img0095te1.jpg |
STICKY STICKY STICKY
Good stuff, he helped with my swap but there's something I like to add if the OP doesn't mind.
Remember on the 04-06 we have the side lights that come on whenever we use the turn signal. You will have to do that on the 07-08 heads. On the 07-08 heads that light is inside the head. Easy fix if you know how to re wire some stuff. This is what I did. I extend the wires coming from those side lights to my harness(car side) and connected to the wires that the fog lights were. The ones you cut to extend to your 07-08 fogs. In other words, two wires go down to the fogs now and two up. |
great write up
Nice job man!
Awesome writeup !! Greatly appreciated! :ben: I look forward to completing my 07/08 front end swap now that I know everything involved, just need to decide if I want to spend a little extra swapping headlights and hood or just modify the contour lines on my 04 hood.
I am really impressed by how some people share some very great infos like this. Do we need to pay you? I mean, as generous as it is, I wish you could be compensated in some way. Well, God will bless your kindness.
Keep up the great work. |
Originally Posted by awdturbo325
(Post 7399030)
awesome write up... im actually in the process!!!
Originally Posted by slvrmax7
(Post 7399368)
I would HIGHLY reccomend getting the 07/08 hood as well man! The lines in it are awesome and flowi n to the bumper in a sharp way...JMO
Along w/ the front swap, I'm looking for 07/08 mufflers since mine are dented anyway. Thanks previous owner! My '04 rear bumper also has a 4" crack, albeit not that noticeable, from bottom lip passenger side. So probably a 07/08 rear bumper in the future as well. This, along with the front end swap, will complete the full-on 07/08 exterior conversion correct? |
Anyone have pix of 06 headlights with 07-08 bumper. I am wondering if it looks good, to save some bucks.
Yes-search the 07-08 front lip prototyping thread, there is a white 6 gen with them on the first page it is I believe. I Strongly recommend getting the 08 lights though- otherwise you will be slamming your hood to close over the 04 lights. Also there are gaps around parts of the 04 lights that I had to "fill" with black garage door sealant foam lol.....get the 08 lights man.
(Post 7401525)
And yeah, that hood is no where to be found. :( |
definitely get the 07-08 hood when doing the swap.... when i did mine i just got the bumper, hood and c-mod grille to complete mine, i kept my 05 lights because i had already modded them (took out amber lens, painted, and angel eyes).... check out sig for pics
Originally Posted by xTeCaOx
(Post 7404389)
Originally Posted by PetitFrereMaxima
(Post 7399166)
I got everything but the hood. That is the hardest to find. I called my local dealer and it's 468 + tax. If nothing comes along when time comes, I might just have to go the dealer route.
Only thing left is the hood for me. Aready rewired the heads and run the fog wires. Blacked out the heads. Im going to paint the bumper in few weeks. http://gi157.photobucket.com/groups/...L/DSCI1655.jpg |
I want to finally complete this mod but I had a question. Being I have a 6th gen and our original fogs are in the headlights, I wanted to convert those to HID along with the ones that I will put in the bumper. If I cut the black and white wires from the headlight harness will this mess up the foglights in the 6th gen headlights from working?
To get both sets of foglights (in headlight & in 6.5 bumper) working correctly, will I need to splice the wires from each set together?? I'm totally confused on this stuff. Any help is appreciated. |
Originally Posted by RAZ76
(Post 7405268)
I have to close the hood a little harder then before but not enough to bother me...... But overall weeeeell worth the conversion
(Post 7405207)
Any problems w/ closing the hood? Maybe I will start w/ hood, bumper, and grill and swap headlights down the road when I stumble onto an HID 07/08 pair at a cheap price.
Asked earlier about this wow good thread
(Post 7410680)
Originally Posted by Propa Teknique
(Post 7410412)
To get both sets of foglights (in headlight & in 6.5 bumper) working correctly, will I need to splice the wires from each set together?? I'm totally confused on this stuff. Any help is appreciated. you can't you'll just keep blowing the fuse. I already tried this with spencer's maxima. You'd have to chose either fogs from the bottom or the 04-06 fogs. |
Originally Posted by thealliance43
(Post 7423877)
Originally Posted by Jammmaxx
(Post 7423945)
Or he may choose to run a seperate switch for the fogs in the bumper.
yes thats true he can do that.. just run a separate line from the battery bridging a switch and u'll be fine
(Post 7424834)
(Post 7410412)
http://www.rowand.net/Shop/Tech/imag...iringGuide.jpg
You can buy 12v relays from radio shack, home depot, etc. maybe 5 bucks Connections: 30 - to positive battery terminal with 20amp in-line fuse 85 - to negative battery terminal 86 - to WHITE wire (+) on headlamp harness (splice into it, having the black wire continue to power the fog lights in the headlamp assy - this will be the trigger for the relay) 87 - to positive wires of fog lights in bumper 87a - no connection hope this helps. pretty much the relay uses a trigger (the WHITE wire on harness) which tells it to supply your fog light with power directly from the battery, as long as the trigger has a 12(+) current. when you turn on your stock fog lights, your bumper fog lights will also turn on, the relay acting like an automatic switch - that way you don't need a seperate switch. if you do want a seperate switch, you can connect the trigger wire to the switch instead. using a relay is the safest method in powering high current circuits. |
any1 kno where i can get side mirror with turn signal lights for my 2008 max? and smoking ur lights they fade off over time?
Originally Posted by ray08max
(Post 7439106)
(Post 7439106)
Originally Posted by cwkim
(Post 7438704)
You can buy 12v relays from radio shack, home depot, etc. maybe 5 bucks Connections: 30 - to positive battery terminal with 20amp in-line fuse 85 - to negative battery terminal 86 - to black wire (+) on headlamp harness (splice into it, having the black wire continue to power the fog lights in the headlamp assy - this will be the trigger for the relay) 87 - to positive wires of fog lights in bumper 87a - no connection hope this helps. pretty much the relay uses a trigger (the black wire on harness) which tells it to supply your fog light with power directly from the battery, as long as the trigger has a 12(+) current. when you turn on your stock fog lights, your bumper fog lights will also turn on, the relay acting like an automatic switch - that way you don't need a seperate switch. if you do want a seperate switch, you can connect the trigger wire to the switch instead. using a relay is the safest method in powering high current circuits. |
(Post 7440462)
Thanks @ CW. I'm still dont understand wiring too well but I'll give this a good. If I need some help, though, I'll be bugging you if you dont mind!
(Post 7440462)
Quick question....I just bought a front bumper cover 2007, do I really need the full bumper set up from a 2007 or can I bolt up this cover to my 2004?
what is the LED mod?
How does it look if you just do the bumper and grill? Is there gaps or does it line up well?
| All times are GMT -7. The time now is 09:01 AM. |
