Pinout diagram for Apexi SAFC-II install.
Hey fellas,
I tried searching everywhere but I can't find the pinout diagram for the 6th gen. I got a Apexi SAFC-II that I'm going to install next weekend but I need the pinout diagram for our ecu. Anyone know where I can download or find a copy? Thanks in advance. Steve |
anyone??
http://boredmder.com/pics/pinouts/th...7%20Maxima.png
Safc red wire (power supply) to pin 109 of small connector red/white stripe Safc green wire (rpm signal) to pin 13 of large connector green Safc purple wire (knock sensor) to pin 15 of large connector white Safc gray wire (throttle signal) to pin 50 of large connector white Safc brown wire (ground) to pin 115 or small connector black (closest to ecm) Safc black wire (ground) to pin 115 of small connector black (1cm after brown wire on same wire of main harness) Safc pink wire (airflow signal output) to pin 51 of large connector green/orange wire (this wire is actually cut and you want the pink wire on the side away from the ecm) Safc orange wire (airflow signal input) to pin 51 of large connector green/orange (connect to the wire still attached to the ecm) |
What are the SAFCII setting for the 6thgen maxima, the in/out on the SAFC? To we still have a Hot wier sensor on the A34 MAF sensor on a 6thgen? Are you sure we use the pink and orange wire on the SAFCII for the airflow signal on a 6thgen and not the yellow and white like they use on the A32 MAF sensor on the 5th gen and 4th gen maxima? Last,to we use the knock sensor on the SAFCII for the 6th gen? becuse on the A32 MAF sensor they dont use the knock sensor on the SAFCII for the maxima!
Originally Posted by EVESNAKE1
(Post 7421827)
Hey fellas,
safcII pin out for the 6thgen
whats the setting for the 6thgen maxma, like the in/out?
im in CT what the name of the place in New york, so i may call them about setting up my SAFCII on my 2006 maxima?
safc 2
If i get the jet's MAF sensor for my 6thgen is it same setting on the SAFCII as the one im going to replace form the 6thgen?
© 2024 MH Sub I, LLC dba Internet Brands
