shift knob loose
Hey guys, my shift knob is a bit loose.. how can i tighten it? service manual only shows a locking pin?! should i just get a new lock pin?
this is an 07 Max, CVT |
Originally Posted by ikalinin
(Post 7544386)
Hey guys, my shift know is a bit loose.. how can i tighten it? service manual only shows a locking pin?! should i just get a new lock pin?
this is an 07 Max, CVT What's a shift know...? :D |
Originally Posted by MadMax07SL
(Post 7544420)
What's funny is that you did it in the subject line as well...:laugh:
Wish I could help, I've never had the noob off... |
This is the way to remove the shift know. You can check the pin if its seated properly or if it its stretched out. When removing the aluminum cone, make sure you are turning it and pulling it down at the same time for removal. If you need an aftermarket know, I have a MoMo shift know that I'm selling
http://img.photobucket.com/albums/v3...ima/steps1.jpg |
my knob was loose also i had the dealer check it out and they replaced it with a new one, it was covered by the factory warranty
aftermarket son
(Post 7544457)
Wish I could help, I've never had the noob off... Never had the what? |
Originally Posted by KCmaxx
(Post 7545540)
Never had the what?
:laugh: So I took it apart. the bottom chrome piece has a broken tab inside, so its not on completely on the knob, so its loose a bit.. other than that, the knob itself, when pressed firmly on the arm, its solid, but i can't get the pin on b/c the little slots where the pins locks into isnt visible.. I have to raise the knob a bit to be able to click the pin in-place.. therefore, its loose.. so im thinking of packing something inside the knob so it sits firmly on the arm.. |
(Post 7545540)
Never had the what?
My knob has been loose since we purchased the vehicle... not a huge annoyance but I don't like when stuff is loose or creaky =\
loose
this seems to maybe be fairly common. I just bought my maxima with 55K miles on it, and the knob is really loose on it. they are going to replace it though.
© 2024 MH Sub I, LLC dba Internet Brands
