Radio Reception
does any one know if the antenna system requires power in the maxima's to work? I checked the schematics and it seems that there is an antenna amplifier which probably requires power to run of course.. post thought and comments..
thanks. |
thanks for the post. i would love to know this too. I have the stock Bose system, and my radio reception sucks!
could be that the antenna amplifier is bad.. thats what i wanna know
If I turn my rear defroster on while the radio is on it goes to static. What's that all about!
I'm still shooting in the dark here but I think in your case, there might be a bad cable from the antenna amplifier to your radio unit. Those cables are shielded and maybe when you turn the rear defogger on, the cable might be picking up stray EMI(electro-magnetic interference) from the defogger... my best eduu-macated guess.
it needs a rear windshield antenna runs in the glass
Ive seen it happen on after market radios when the blue/wht wire isnt connected... also if your car once had an after market when they put it back to factory they like to forget to ground the radio.... they like to short cut and just plug the antenna in and let the radio ground threw that..
Nissan radios have a bolt in the back that a ground strap usually goes to. Its a 10mm head. |
i thought its a green/white wire.?
Originally Posted by chris350
(Post 7942346)
Yea I have seen the grn/wht with that plastic pinch clip. good call forgot about that! |
(Post 7940488)
thanks. |
Originally Posted by acercomp71
(Post 7942496)
yes it is pin#5 from connector M43 (for non-bose late production version) and this connection is essential for good radio reception. i made a separate post about this for clarification.
Originally Posted by officerfrasher
(Post 7942501)
You said for non-Bose - is there anything special for the Bose?
confirmed NON BOSE, Pin 5 green/white wire. So I would assume that I would have to just connect a 12 volt switched( of course) source to that pin and all should be fine?
(Post 7943186)
I put some dynamat on the trunk lid because it was rattling with the bose. Ever since then the radio reception is little to nothing.
© 2024 MH Sub I, LLC dba Internet Brands
