JDM NISSAN Z32 CALIPERS
will the JDM NISSAN Z32 30MM aluminum calipers fit my
2004 Maxima SE they came off a 1996 300ZX (Z32 twin turbo).
any feed back would be greatly appreciated. im planning on doing
F and R do i also need any other harness to make it work..thanks
would i be fine with the oem rotor..thanks for the feed back
you will need brackets to make them work.
even with the cobra brackets you can still run the 12.6 rotors, but you wouldnt be using the full face of the pad.
12.6 - 13inch rotors, so .4 of the pad you arent using.
than i anticipated..might just have to wait..thanks though
Brackets are $65 , decent HAWKs pads are about $50
using your 12.6 rotors, your still under $500
do u happen to have a pair if u do i would buy those off u...
and would i have to replace the brake lines or is it plug and play for the most part....
bbsitum
09-11-2015 04:55 PM
