What brake pads and rotors?
Hi guys
Going to try changing my front pads and rotors for the first time myself. Can anyone recommend good products for each? Something better than the OEM ones, but nothing too crazy. I dont race or anything ... just normal city and highway driving.
thanks a lot
thanks a lot
I dont know if "powerstop" makes any for your gen but they are really good quality and cheap. You can get a front and rear set with drilled/slotted rotors and ceramic pads for a few hundo. ANy of the Ebay brands are the same thing, lots of .org 4th gen and 5th gen owners run them and they last surprisingly long for the price point
they come drilled and slotted. If he was tracing it then I would say go only with slotted because the drills are knows to expand and break but for a DD drilled and slotted is fine. You can never have enough stopping power, its a safety thing.
Flemmy,
See my post here. This should be very helpful to you.
http://forums.maxima.org/6th-generat...endations.html
Dave
Dave
Hawk HP pads I think are the best you can get (for stopping power), I always use solid brembo's, I can locked them at 70 (who needs big brake kits).
The con's, they are noisy, squeal, and probably wear out fast/uneven.
I highly suggest OEM. If you will go with non-OEM, stick with the same friction coefficient. Car makers have engineers and they used those specs for a reason One thing with ceramic pads, they will eat your rotors fast.
The point of the aftermarket is to offer a higher friction coefficient and thus better stopping power. Suggesting one sticks with OEM when they are trying to upgrade is kind of ridiculous. Nissan used the rotors and pads they did because whoever won the bid to supply them offered the lowest price, not becuase they worked the best with the calipers. Upgrading from OEM only helps
Laevateinn
Please define "ceramic pads, they will eat your rotors fast"
How much faster than performance metallic pads or OEM? How long will it take with ceramic pads to bring oem rotors below min thickness level?
Any serious articles to support this?
Or you don't really know what you are talking about?
I did my front brakes on my 99 last year. I used Adaptive One pads from NAPA and rotors they sold for around $30 ea or so. Impressive stopping for a somewhat cheaper job. Little dusty, but not as bad as what others have shown in pictures.
May the stopping force be with you!
I would go to canadian tire or something like that (your car parts store) and get the best OEM quality ceramic pads and rotors you can get, and thats it.
I have hawk hps pads, they work, but it's not needed for regular driving, plus they dust a lot compared to ceramics, and they dont even come with clips.
quick question, i have an 03 maxima 6sp. and i purchased the duralast gold rotors for the rears and rear ceramic brake pads. the new rotors are regular rotors. so the question is my rear rotors are slotted. will i still be able to put my rotors and pads in with no problem?
04-16-2020 05:15 AM
HerpDerp1919
09-29-2015 02:02 PM
