Stucked park-brake interlock solenoid
My 2004SE has 107000miles. Today I think it has a stucked park-brake interlock solenoid (the Brake switch is still working). I can't get the Shifter to go gears.
So now I'm driving with a screwdriver in the Shift-Lock bypass hole.
What would be the cost to replace ? Anyone has a suggestion ?
Thanks.
Thanks.
If your brake lights still work then the brake switch is good. Next culprit is the shift-lock solenoid in the shifter assembly. Take it apart and see if there is voltage present when the brakes are applied to shift out of park.
Parking brake has nothing to do with gear selection BTW.
Updates
Thanks for all the suggestions.
First thing I checked was the brake light, so I knew it's not the brake-switch ---> so it should not be the fuse --> must be the solenoid.
I don't eat nor drink in the car, so it should not sticky due to foreign object.
My mechanic said it would cost $31 for the solenoid. But the kicker is it would take 2.5-3 hours for labor --> estimate is <$150 for the fix. Man, why do they make it so difficult for such a replacement ? The part has to be special-ordered, so I have to live with the screwdriver-fix until next week.
About $30 with after shipping.
http://www.courtesyparts.com/34970-s...4-p-92411.html
Never changed it but it does not look hard to get to. Probably a simple 30 minute job with simple tools.
http://www.courtesyparts.com/maxima-...2732_2751.html
No I was referring to a fuse for the transmission lock. It has nothing to do with brake light. If the fuse is blown, solenoid has no current, therefore, it will not engage. I do not remember which fuse it is, if you want to go easy route, pull fuses one by one and visually inspect them. Make sure you remove the keys from ignition or you may trip CEL while pulling fuses
Many people do not realize that there is a fuse in shifter lock circuit and blame brake switch or shifter lock solenoid when shifter gets stuck in "park", Yes it is possible that either switch or solenoid failed, but check on fuses first. Check#12, 19, 20, and 21.
Do you still think it has nothing to do with the brake lights?
I agree with you though about checking the fuses first, but you need to know which ones. OP check both the fuses for "Electronic Parts" and the one for "Stop Lamp".
Updates.
I didn't think it was any fuses, since everything else is working. A multifunction fuse would blow a few other things.
I went ahead to check the fuses anyway and none was bad.
Nowadays, I'm no-longer adventurous with spending hours fixing things (getting old).
So will just let the friendly mechanic earn his livings.
As far as I remember, when my shifter would no go out of "park", brake lights would still work just fine. In fact, everything else worked just fine. The only problem was shift lock. I honestly am not sure though, don't take my word, it was few years ago. Anyway, I simply pulled all fuses one by one, and found one that was burnt. But hey, OP says all fuses are good, so the problem lays elsewhere anyway, perhaps, brake pedal switch or solenoid itself.
Speaking of switch, when I had a '97, it was a total PITA to replace, not sure if it is any easier on 6th gen.
There is a white box in the fuse box area, that has a bolt on it remove that bolt and replace the "shift box" 9/10, that "shift assy control" is the problem its notorious for failing in the 6th gen maxima. It's also an occurrence on the murano forums.
At first, they thought it was the solenoid which is a much tougher job.
tarun900
19
12-20-2021 06:57 PM
RealityCheck
10-02-2015 06:34 PM
HerpDerp1919
09-29-2015 02:02 PM
