6 Gen Climate Control FSM Manual section?
If anyone has the climate control section for the 6th gen that would be greatly appreciated. I mainly just need to know the low and high side pressures for charging my system. Thanks.
The low side is the one with the bigger pipe (with hose) and a smaller lid; the high side has a smaller pipe with a bigger lid. The low side is the suction, and the high side the discharge.
Originally Posted by Costee
(Post 8752319)
Originally Posted by QwikKota
(Post 8752325)
Yes, I would like to know the low/high side pressures to charge to however.
(Post 8752381)
You charge with the low side. That's why it's called suction.
(Post 8752549)
I'm sorry, but I believe you have a reading comprehension problem. I needed to know the exact pressure to charge to. I purchased a manual, it is 142psi at 77°F outside.
(Post 8752706)
Now I know why this thread has received no response from forum members.
Not many people work on their own a/c, and very few know the exact pressure to charge to. That is why there has only been a few replies. |
A quick look at the index suggests that this may be your section..
http://www.nicoclub.com/FSM/Maxima/2006_Maxima/atc.pdf |
Just noticed you have a 2007. I doubt its different but here is the 2007 Max FSM..
http://www.nicoclub.com/FSM/Maxima/2007_Maxima/ |
Originally Posted by DrewSER
(Post 8752850)
© 2024 MH Sub I, LLC dba Internet Brands
