Car battery keeps dying, is it battery or alternator?
My 2007 maxima has 171,00 miles. I bought it in Dec 2012 with 39,000 miles. After a few thousand miles the battery had to be replaced. Now a couple of years later I have had to jump start my car twice in the last few days. It wont seem to hold a charge. Is there a way I can tell if its the battery or the alternator? Thanks guys!
You can bring it to a parts store like autozone or advanced and they can come out and test it for you to see if your battery isnt holding a charge.
If its after a few days that your battery keeps dying after being jumped, it sounds like your battery cause if your alternator wasn't charging it, it would die within hours.
check your ground to frame/transmission wire.
Mine was corroded and causing a slow resistive leak, and batteries would not last because they would feeeze because of the low charge.
No more issues now.
Have your battery tested, and check your ground.
No more issues now.
how was the ground to frame/transmission cable? I started getting dead batteries when mine went bad. Replaced it, and then a new battery, and all good now. I also added a ground kit just in case and to make sure I would not have any more issues with that ever.
You must commute allot lol
Take the bat terminals off, sand them down or clean them up with baking soda, crank those suckers down like the ****ens, as tight as you can get them without stripping anything. works 95% of the time with fairly new batteries.
I've always had my terminals barely hanging on in my other cars with no problems, but my max needs them TIGHT as hell or else it will drain overnight. Im serious tighten them down with some muscle. if that doesn't work, look at your ground wire, if that is intact, you have a bad battery. This problem can be figured out very easily
DuMKuH
03-04-2010 01:26 PM
GarciaMaxima
06-21-2004 07:33 PM
eaglclon
10-20-2002 07:47 PM
