idler pulley lock nut thread size
im gonna be replacing a idler pulley lock nut in a couple days. they are 14mm i believe. What is the thread size on the nut? Will M12-1.75 be a good fit? thanks
If it's a 14mm nut, it is unlikely the thread is 12mm. That leaves only 1mm for the walls which is less than 1/32". 10mm fine thread sounds more likely. You need a flanged high-strength nut, so if possible, take the original one to an industrial fastener place, or to the dealer.
If it's rounded, get yourself a 14mm Grip-Tite wrench and save yourself considerable frustration, you're not getting a socket in there...
Just replaced one last week. It is an M10-1.25 flat faced flange nut. You won't find it at your local hardware store but you should be able to get one from a decent auto store, I found mine at Canadian Tire and I think it was a pack of 4.
