2005 Max cranks but won't start
2005 Max will crank but won't start
I have 2005 Max, 270,00 miles and AutoTransmission. I replaced the flex plate, 2 Cam Sensor, Crankshaft Sensor, spark plugs, coil packs,valve cover gasket, battery, and alternator. I changed all them and still my car won't crank. I don't know what could be the problem to cause my car not too crank. Need HELP!!!!! Can anyone give me some sound advice. |
Not sure what it could be, but have you checked/replaced the starter? even the cables/wires.
Originally Posted by follyburr
(Post 9152816)
If I'm reading it correctly, you meant to say 270,000 miles? With that kind of usage, hell it could even be the compression in multiple cylinders is so low you can't get a good explosion! Damn, I hope you get it narrowed down!
The code reader is saying that I have bad crank sensor and cam sensor. I just change all three sensor before I change the flywheel. Do you think it could be timimg is off???
Originally Posted by Eljuane803
(Post 9153022)
| All times are GMT -7. The time now is 09:41 PM. |
