)4 Maxima Cranks but wont Start
Old 07-23-2018, 05:30 PM
My 04 Maxima originally threw a code for cam sensor bank 1. I changed the sensor.. ( Have used multiple....OEM and aftermarket) no luck. if I unplug bank 1 it will start and run in limp mode. I have tried changing all the spark plugs, all of the coils, changed the crank sensor also, replaced the starter, checked the wiring harness for imperfections. I am at a loss. I was just driving it one day and it just acted like it died. I have an extra ECU I picked up from the junk yard but there is no point in throwing it in because I would have to program t to the key and I am not sure that it is the problem. It is not throwing any codes now. I also grabbed a PCMfrom the junk yard. Does anyone know if that has to be programmed as well? Any help would be greatly appreciated.
Mike19852607 is offline
Old 07-31-2018, 09:34 AM
Hey there!
Iím no professional by any means. No hate please.
have you checked fuel pressure?
The cam sensor: have you tested the old sensor to see if it was the issue? If you run a new sensor and still nothing it may be what the sensor is reading. Like a rotational magnet of some sort.
My diagnosis for a crank no start is spark check, air check, and fuel check.
Davisnathan49 is offline
Old 08-02-2018, 11:30 PM
Check the ignition timing. Might be off.
Costee is offline
Old 02-20-2019, 03:26 PM
are you sure you are replacing the sensor in bank#1? have you tried a non good sensor? ( not after market )
illrooster5861 is offline
sdotcarter
01-11-2017 05:49 AM
Tapio
23
04-14-2009 04:46 AM
WielkiWaac
06-21-2006 03:59 PM
wunfstmax
10-27-2005 11:34 AM
racin89lx
08-08-2005 10:57 AM
Quick Reply: )4 Maxima Cranks but wont Start
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
