Can I swap my TPMS from my 18's to my 19's without resetting, or do I have to reset?
Just got some stock 19's and put them on my car, obviously the TPMS warning lightly has come on and needs to be reset. Can I swap the TPMS from the 18's on here without resetting to get the light to go off? Or do I have to reset it using the process found here (which seems crazy) : http://forums.maxima.org/7th-generat...pms-reset.html
Originally Posted by danielevans83
(Post 7955532)
Is there a thread on how to do that? Or do you know how? Never messed with TPMS before.
(Post 7955561)
Originally Posted by mrodenberg0124
(Post 7955597)
It's connected to your valve stem and just unscrews. You will have to break the seal on each tire, unscrew the current stem, put your old ones with the sensors on, and then air your tires back up.
(Post 7956172)
What do you mean by break the seal? Sorry if I sound ignorant here. Sounds like I don't have to take the tire off, but have to let a lot of air out of the tire so I should obviously jack the car up and do 1 at a time. Good time for me to bust out my borderline-never-used air compressor in the basement to fill em back up.
(Post 7956172)
Yeah you don't have to completely remove the tire from the rim. Just break the seal where your valve stem is, swap, and air that sucker back up. You are probably going to need something pretty beefy to get some leverage on the tire with to be able to pull it back far enough to unscrew the nuts holding the valve stem in place. |
Trust me, you need a tire shop with the proper equipment to do this. The tire beads on the short sidewall tires are very difficult to break down & re-seat. The bead must be pushed down quite a distance in order to remove the sensors. All you need is to damage a couple of places on the wheels to wish you had let a professional do this correctly for you. Pay the man and get on with it.:)
Originally Posted by oldngivout
(Post 7957072)
He might even get lucky and find a place that will just break it for him for free. It's not like the actual swap or airing a tire up is rocket science. |
(Post 7957253)
Unless you just have the time on your hands, yes most likely it'd be best to go to a tire shop. It is possible without the equipment just takes a while. Luckily my roommate works at an autoshop so it was a quick 2 minute swap for me.
He might even get lucky and find a place that will just break it for him for free. It's not like the actual swap or airing a tire up is rocket science. Speaking of which how do others deal with this when they swap off/on rims for the summer/winter? You keep moving your TPMS, you reset it, or do you just ignore the light? |
(Post 7957282)
Hmm, okay I think I'll run this over to my mechanic and see what he'd charge me to swap these off. From what I gather it's ~60-70 to pay Nissan to reset the TPMS sensor isn't it? Then again the light isn't THAT annoying...lol...
Speaking of which how do others deal with this when they swap off/on rims for the summer/winter? You keep moving your TPMS, you resetwe it, or do you just ignore the light? |
Originally Posted by Kmoney
(Post 7957431)
Well I just got 20's staggered and I am bout to buy new tpms sensor for the rims as well so I wont need to keep changing sensors
(Post 7957436)
Wait, so once they're set for your car they're good forever?
(Post 7959141)
Yes, that one set of four TPS sensors is, but not the next set. Each one has to be individually recognized by the car. It will only (see) 4 at a time. It's not like keyless remotes where you can have up to 4 for one car.
I would love to know the answer to this as well. I am considering buying stock 19s to replace the 18s that are on my 2011 Max & want to know if the TPMS sensors on my current tires can be used with the 19s...if so, is this something a tire shop can do easily?
Originally Posted by Techsan
(Post 8961427)
Yes, and Yes |
You can break the bead and swap the sensors. You are looking at $40+ in labor.
My local shop, discount tire, will reset the tpms light for free when I swap wheels, as I bought both sets of tires there, and have sensors in both sets. Why not just buy a second set of sensors? |
Sorry, I have a related question and did not want to start a new thread on this... For those who were using winter tires on your 7th Gens, did you need to have your TPMS relearned when you were putting your all-year OEM tires/rims back in March/April? I realize that the TMPS light was on during the winter (unless a separate sensors set was purchased for the winter tires), so did the light disappear automatically once you put your OEM tires back on?
Thanks a lot. |
Originally Posted by elevit
(Post 8974330)
Thanks a lot. |
Thank you very much for the confirmation gizzsdad!
Originally Posted by gizzsdad
(Post 8974566)
No need to relearn. Light went out within a few starts.
I have access to a tire machine and still broke 2 sensors trying to swap them,,,,,,where is the best deal on SV sensors???
Possibly RockAuto
| All times are GMT -7. The time now is 11:28 AM. |
