Best After Market Brakes And Rotors
ok its time for me to get new brakes sense my front rotors are warped and needs replacing ,whats good in the aftermarket world to get i wanted a big brake kit but not looking to spend 3g,maybe some slotted rotors and racing brake pads any ideas.
Originally Posted by 2009maxima sv-sport
(Post 8374027)
i been looking at ebc brakes are they any good i like there race pads
Search for Brakemotive on Ebay... They have some of the best quality stuff money can buy... Super reasonable as well... Just did all four rotors and pads on my car and couldnt be happier....
i got Alien drilled/slotted rotors, ceramic brake pads, stainless steel brake lines, and dot 4 Motul brake fluid that I just put on my whip. stops on a DIME. the Alien brakes are popular among the my6th and m7thgen.org sites and many people using them with Wilwood BBK's too and other BBK's.
I got in on a sweet *** group deal on those forums and paid 350 including shipping. Best money I've spent on the car so far. If you're interested check out those forums and search on Alien brakes they're sick. Just took a couple hours to install. https://lh6.googleusercontent.com/-C...6/IMAG1248.jpg https://lh3.googleusercontent.com/-2...2/IMAG1255.jpg https://lh6.googleusercontent.com/-L...2/IMAG1266.jpg |
Originally Posted by Ghozt
(Post 8374285)
based on the pics, looks like he swapped the brake lines. So you will need someone competent to bleed the brakes. The rotors are direct factory replacements. So that is a fairly simple job. Put the EBrake on. Jack up the car. Take off the wheel. Remove the caliper. Swap the rotors. Some brakes require shim kits for the pads some don't, you will have to look. Swap the pads. Swap the lines. Bleed the brakes. Put it all back together. If this were just a brake job, no lines or fluid bleeding, 20 minutes to do both wheels. With lines figure 45 to an hour to properly bleed the brakes. You don't want to rush that, it goes without saying that this is a vital safety component of your vehicle.
i used 2 bottles cuz I flushed it all out then had to bleed the brakes to get air bubbles out.
the rotors /pads werent hard at all. just need a breaker-bar to get some of those tough bolts off the calipers. cleaned everything up with brake cleaner and a little wire brush, greased every moving part(piston/slides) and the back/sides of the pads, put everything back together with the new rotors/pads, pumped the brakes, went and did the bed-in and they've been working great. i did my front axle first (just rotors/pads) and drove around and bedded them in, then did the rear axle a week later, and did the brake lines/brake fluid a week beyond that separately. i did it this way partially because im not a pro at brake-work and wanted to make sure i had at least 2 working brakes in case anything went wrong, and partially so i could see the braking power slowly increase with each stage and see exactly what the rotors vs the brake lines did. im impressed with the brake lines there is absolutely no more mushy feeling and things are flying off my seats all the time now lol. vr4z06gt is right if you just did pads/calipers you dont need to disconnect the brake lines/bleed brakes (you hang the caliper using a wire hanger so it doesnt dangle from the brake line) and it can be quick (if you know what you're doing). if you dont id recommend getting a buddy who has to either help you or do it themselves or paying someone cause you do NOT want to mess up a brake install because it can be LIFE OR DEATH. Alien used to only sell on eBay and have been migrating into the forums for promotion recently. if you want to hit them up their email is alienbrakes@yahoo.com. |
(Post 8374285)
also they paint the rotor hats at request, i requested black but i know they do several other colors.
here's a pic, please excuse the dirty rims they cant be clean every day lol https://lh3.googleusercontent.com/-j...6/IMAG1347.jpg |
(Post 8374596)
oh also the motul brake fluid was purchased separately and probably isnt necessary unless you're gonna track the car so sorry to imply that was included with the alien brakes deal.
thanks guys |
Looks good Ghozt
Are bigger rotors available? I love the slotted look but would love a rotor that took up more space. I dont know much about brakes. Can this be done without bigger pads?? Or is that known a Big Brake Kit?
yea you can get bigger rotors (14") with a BBK. cant run them with our stock caliper bridge cause the caliper wont fit around the rotor.
i have hawk hps and i love them they stop on the dime!
dumb question but will these alien ones fit on a stock 4th gen SE?
(Post 8374836)
i dont know if these would fit the 4th gen. what is the lug pattern and diameter of the 4th gen rotors?
you can probably email them and ask if they have a set for the 4th gen im sure they can help you out hawks are great, when these that came with my set are done im going with hawks too |
yea i think they are half ceramic so they make waaaay less brake dust and they stop better too
(Post 8374852)
Good to know. May keep brake swap in mind when the time comes
ok i went with EBC 3GD Slotted & Drilled performance Brake Rotors front and rear and the EBC yellowstuff brake pads also ordered 2 bottles of Motul brake fluid and Goodridge Nissan Maxima stainless steel Brake Lines (2009-2010) 22136 will keep people posted.
EBC makes good stuff too, I had green stuff pads with my stock rotors they were pretty good. Good choice on the Goodridge brake lines those are #1 in terms of quality. You're gonna love your brakes man really good choice in an upgrade
(Post 8375345)
all together i ended up costing me $790 for all the rotors and pads fluid and brakelines shipped front and rear i almost bought the stillen bbk but it was $2290 for front and rear shipped :bawling: |
sorry for the dumb question but why is it called for to have the metal brake lines?
Usually it would be steal braided, low expansion rubber/silicon blend for brake line. The benefits of moving away from standard brake lines is non- existent for most people in most driving situations.
It's based on how they deal with heat. When the brakes get used repeatedly in higher stress situations (autoX or track days) the temperature of the brake fluid will rise dramatically. This causes expansion of the brake line which in turn can cause significant brake fade leading up to potential braking failure. A steal braided long prevent most of the expansion and allows you to maintain more consistent pressure longer. Usually most race oriented brake lines are a combination of metal and steal braided for use. Downside of all metal is typically they don't fully support the full extent of wheel travel required for a stock suspension. They Are also more temperature sensitive in the cold as you get started..... If you are going to upgrade your brakes (size, more aggressive pad) steal braided lines (typically 80-150 per axel) is an excellent way to go. |
^ yes exactly. normal brake lines are rubber and flex under high temp/high pressure situations like hard braking you'd do at the track. less flex = less mushy feeling = more response in higher stress situations basically. dont cheap out on brake lines either, the connections can blow off when you stomp the brake
and yeah brake lines aren't necessary for a daily driver. same with high temp Dot4 brake fluid or a BBK. im looking at a 4 piston BBK for the front only but sure as hell not paying Stillens prices lol those guys are crazy. we'll figure out how to use the 370z BBK for a nice oem look. |
(Post 8377738)
Originally Posted by longisland09maxima
(Post 8374797)
http://www.conceptzperformance.com/C...298.191.127.76 Read this thread for more info: http://forums.maxima.org/7th-generat...10-brakes.html |
2 Attachment(s)
Attachment 53749
Attachment 53750 got my brakes on EBC 3GD Slotted & Drilled performance Brake Rotors front and rear and the EBC yellowstuff brake pads also Motul brake fluid and Goodridge Nissan Maxima stainless steel Brake Lines,so far i love them they stop alot better very little pad noise so far,just bedded them in and its parked for the nite will fell them out better tomorrow waiting on MGP Caliper Covers to finish off the poor mans big brake kit. |
Sorry to bump this old thread but was wondering how are those Alien rotors holding up after using them for these past few months. Thinking about changing my rotors and looking for some good ones that won't break my wallet.
so far so good; everything holding up great and still stopping great. only thing id have done in retrospect is maybe get some better pads, the ones they include are generic ceramic ones. HAWK HPS or EBC Reds would make this great, but it's already pretty damn good.
i want to get aftermarket rotors (will need them soon anyway) and probably will change the pads as well. I want a setup that will not squeek etc. any recommendations?
(Post 8665467)
Thanks Ghozt! One other question regarding the SS brake lines. What brand are they and did you change the rear lines as well. Thanks. |
Originally Posted by nismo2010
(Post 8666235)
http://farm9.staticflickr.com/8480/8...41e8017c_z.jpgGot that Stillen brake kit...
(Post 8666261)
Goodridge, and yeah they come as a set of 4
After quite a bit of research, I just ordered dimpled and slotted rotors from brakeperformance.com, along with their premium semi-metallic pads.
Lifetime guarantee - really looking forward to this. |
I am still loving the rotors from alien brakes... No rust on hub... Black paint is still holding up...I kept the factory pads... I am eventually going to get the akebono front and rear setup...i want to do the Stillen kit but there is no rear kit by Stillen and I get all 4 for cheaper than Stillen kit... Just makes sense...
© 2024 MH Sub I, LLC dba Internet Brands
