iPhone doesn't pair every time???
Hey everyone,
My first post! I picked up an '09 Maxima and absolutely love it! I have an iPhone 4 and set everything up to pair via bluetooth to the car... however it doesn't pair every single time I get in the car. When it does not pair, as soon as I click on the "Setting" app on my phone, it pairs right away. Kind of annoying having to look out for it every time. Any thoughts/fixes/suggestions? Thanks! |
is your bluetooth connectivity always on with the iphone...i have no issues at all with my galaxy s connects everytime
Yup, and I would say about 80-90% of the time it works perfectly. Sometimes it just doesn't see it.
Anyone else experience this? |
Not with an iphone but yes it happens.
I have the same exact issue with my 2009 and IPhone 4. I do the same thing, head to the settings app.
Isn't it weird?! I'm trying to find a pattern but it just seems random.
are you guys up to date with the latest iOS for the iPhone also are you jailbroken?
I am up to date. Actually just got another update a day or 2 ago. I'm running 5.1.1 right now.
Mine is not jailbroken, just plain old phone. |
Originally Posted by gofastgt
(Post 8470868)
No I haven't, it pairs to my headset with no problems as soon as I turn it on. Haven't had a car with the BT before so can't compare there.
Bummer! |
Do you ever reset it... Holding down the home button along with the standby button on top?
Every night :)
Great thoughts, I really appreciate the help brainstorming! |
One other thing do you just leave your BT on all the time? I only turn the BT on when I am going to be using it and then I turn it off
Are you asking about my BT headset, or the BT feature on the phone? I don't keep my headset on (it's actually at home) and I do keep the feature on on my phone. I tried switching it off and on as well but it still acts funny.
(Post 8470692)
Yep no pattern, just random. |
Did anyone ever get this figured out??? My iPhone 4 doesn't pair hardly ever unless I go into the settings app. I'm running iOS 6.0.1 and have a 2009 Maxima with the Nav system.
Originally Posted by JakeOfAllTrades
(Post 8712172)
Hey Jake. This is the OP. I never figured it out. I also have the 09 Max with the Nav, and am also using an iPhone 4 with 6.0.1. After I got the latest update to 6.0.1, not only do I have to hit Settings, I actually have to click on Settings, and then click on Bluetooth! It's so annoying! In May I upgrade to the iPhone 5 and if that doesn't fix it, I'm getting a new car! LOL I love technology... until it sucks...
Even before my iphone 4, I had a HTC tilt that also had this issue. Both the tilt and the iPhone 4 have Bluetooth protocol of 2.1 or lower. The iphone 5 supports protocol of 4.0. But the issues with the 2009 Maxima lie in the phone itself. If I were still in your boat, i would go with the IPhone 5 or more.
But as you can see from this article, there were known issues with the Bluetooth implementation in the iPhone 4. http://iphone4bluetooth.com/the-ipho...-improvements/ |
My iPhone 4 is on ios6 and never had an issue pairing
Originally Posted by 09Maxima_Sam
(Post 8712203)
Originally Posted by PSU09MAXIMA
(Post 8712209)
I'm going into the dealership to have a backup key programmed on Friday. I mentioned the issue and they said they would look into it and see if there are any firmware updates for the Nav unit or anything. I'll post again after.
Just out of curiosity... How are you iPhone 5ers connecting your phone to play music in the 2009 Maxima? Right now I have a little adapter that changes the connector from the 'old style' that is used by the maxima to the style used by the iPhone 4(to allow me to charge my phone while listening to music). If I get the iPhone 5 will I have to get another adapter that plugs into the adapter I already have on there??? or do they make adapters that convert the cable that comes out of the car straight to the new iPhone 5 connector?
It should be a standard 30pin to lightning adapter that plugs into the one used by the maxima. http://www.ebay.com/itm/8-Pin-to-30-...item19d82955a2 These can also be purchased at the apple store/electronics big boxes for quite a bit more.
Do you use your current adapter that connects to the one used by the maxima just to add charging capability to your iphone 4? Can you describe this adapter or post a link to what it looks like on ebay? |
How do you pair the phone? I have an iPhone 4S and a 2012 SV w/ Prem and NO Tech. I can't get the phone to recognize the car even in the setting menu under Bluetooth. Tried to press and hold cars talk button and I hit it again and it says no phones available but my phone is discoverable. :confused:
Did you go through the pairing process by pressing the call answer button once on the steering wheel?
Thanks. I was holding the button too long. Worked.
1 Attachment(s)
Originally Posted by MaxSport9
(Post 8712552)
http://www.cablejive.com/products/dockStubz.html There are other products out there like this, but I LOVE this one. It fits really snugly, and "locks" onto the Max cable but disconnects easily(but not too easily) from the iPhone. Charges my iPhone 4 via the Max cable and I don't even have to take it out of it's case. An update about pairing: I took my Max into the dealership to have a backup key programmed today and asked if there was a firmware update or anything else that might fix my problem. All my firmware was up to date. I was about to give up but figured I'd give one more thing a try. I think I fixed my problem (phone wouldn't connect unless I went into bluetooth settings menu on my phone every time I started my car). Here's what I did:
| All times are GMT -7. The time now is 10:11 PM. |
