Eibach's
So got a quote from a lOcal Nissan Performace shop to install my Eibach's they said $290 I'm in PA wondered if that's high or a good price. Also should I get an alignment done right after or give it a week or two for the springs to settle? Appreciate the feedback.
Good price to me. I paid $210 for mine and installed my myself.
Originally Posted by PSU09MAXIMA
(Post 8524071)
definitly let them settle for at least 5 days and as for the price it all depends on who u go to i had mine done for $150.00 but to be honest with u i found that the ride was really bouncy so i took them off! coilovers are the way to go so if u havent installed them yet think about it real good because that money can go towards ur coilovers i made that mistake FYI Good Luck bro..
thanks guys yeah I haven't pulled the trigger yet for sure but being my DD I figured springs were prolly better than going coils
I think that is a good install price. The several shops I checked with in central jersey wanted $400 and up ($500 for adding the alignment). If you do pull the trigger, let me know where this shop is located.
Coilovers seem to be the most popular choice here, but the cost of a set of those is three times the cost of the spring set, unless someone has a good source for them. |
Originally Posted by AlDente67
(Post 8524580)
Coilovers seem to be the most popular choice here, but the cost of a set of those is three times the cost of the spring set, unless someone has a good source for them. I feel like for me coils wouldnt be worth it because I really dont want to go lower then the eibach drop 1.3" in front and 1.4" in the rear. Also being my car is my DD and with snow and all that stuff I feel like springs are the best bet for the look and handling |
(Post 8524586)
It's called Import Intelligence they are in West Chester, PA know you're in Jersey but dont know how far.
I feel like for me coils wouldnt be worth it because I really dont want to go lower then the eibach drop 1.3" in front and 1.4" in the rear. Also being my car is my DD and with snow and all that stuff I feel like springs are the best bet for the look and handling I see it now...west of Philly. 72 miles away from me. I'm leaning toward the springs as well. We have some driveway entrance angles here that are not friendly to a super-low suspension. |
(Post 8524604)
I'm leaning toward the springs as well. We have some driveway entrance angles here that are not friendly to a super-low suspension. Also I feel like with Coils I'd prolly drop it like the same amount as the springs |
btw take it to a shop you trust and ask IF you need an alignment at all. when I had my springs installed I did not need an alignment, everything was in spec. when I changed the offset (by adding spacers and then later different rims) THAT is when I needed an alignment. but if you just go to a shop and say "give me an alignment" they'll charge you for one regardless if you need it or not
Originally Posted by Ghozt
(Post 8524646)
Yeah man thanks. The place I will plan on going to called Import Intelligence friends of mine have dealt with them in the past so I trust them. But yeah I'll make sure I say do I need an alignment. After you dropped your Maxima did you drive a few 100 miles then get the alignment checked? |
just Slam it bro.... lol.
Also to those of you out there that have the Eibach Pro Kit installed is the drop really 1.3 Front and 1.4 Rear or is it more like 2in all around heard that it is more like 2in all around
(Post 8525024)
my drop settled to like 1.5" give or take a 10th. not slammed but a few people asked if i have coilovers in person |
(Post 8525059)
yeah i drove it around and asked my boy again few hundred miles later he said i was fine. it depends on if the car was ever aligned recently to begin with, i think some people just have a car thats out of alignment and install springs.
(Post 8525059)
How is the ride?
After you got the Eibach springs installed, how was the ride compared to the stock springs? I really like the look of it lowered but not sure how the ride is going to be. I read some reviews and they talk about better gas mileage, is that true? Thanks, Tommy
The drop will be like 1.5 in the rear. Your steering response will improve, and because it is lower, you will be able to take corners at higher speeds if you choose. I really enjoy my Eibach drop. I think you will to.
(Post 8524071)
Originally Posted by Timmy
(Post 8530426)
Try VHP shop its located at 1302 E Tilghman St Allentown PA 18109. If you'll make it there ask for Serge his the owner and tell him that Tim from NY send you there. This dude been a mechanic for a while and his specialty is tuning so he should be able to give you a better price.
Thanks man |
installation is really easy, if I could do it then anyone could do it !
Eibach's kit, new wheels and ride quality
Gentlemen,
I want to lower the car and get new wheels--What would be the best wheel size to retain ride quality in a daily driver? Keep in mind I am in Chicago and the roads are horrible. Thanks in advance. |
anything bigger than 19's it may be a little more bumpy than you want for a DD. i stuck with 19's and put 245/19/40 Hankook tires on. kept my 18's for the winter due to the all-season tires. if you want 19's though and all-seasons, the Generals are pretty good tires
Originally Posted by mimmoc
(Post 8552892)
Gentlemen,
I want to lower the car and get new wheels--What would be the best wheel size to retain ride quality in a daily driver? Keep in mind I am in Chicago and the roads are horrible. Thanks in advance. I'm in WA state (also with poor roads and drivers) and I will for now keep my 18" wheel/tire setup. Still what to retain some balance between ride comfort and handling. I'm too old to give a crap about a perfect "looking whip" at the sacrifice of ride quality. It's a daily driver for me right now. Looking at something respectable with possible spacers to help out. When you start out with the 7th Max you are a step ahead in the stylin dept IMOP! My Eibachs just shipped today. |
Originally Posted by BBmaxi
(Post 8530582)
| All times are GMT -7. The time now is 07:20 AM. |
