Bully Dog GT Gsa Tuner
Old 09-29-2012, 09:27 PM
Makc1kNYC's Avatar
Hey guy's I just wanted to know is it worth it to buy this Bully Dog for my Maxima? Does it really advance the timing +2, removes the governor and gives you a full throttle after 100Mph?
Let me know because I don't want to throw my money away .
Makc1kNYC is offline
Old 10-01-2012, 08:34 PM
t8kover's Avatar
Yes, it will do all that. I enjoy my BullyDog, you can set you RPM, maximum MPH, not that you will go that fast but you can set it. Plus you can monitor your critical systems on the fly.
t8kover is offline
Old 10-01-2012, 09:22 PM
Jodius Tha Warrior's Avatar
+2 timing is nice, but +4 timing is awesome! I like to mess with the timing from time to time. Makes for fun weekend driving.
Jodius Tha Warrior is offline
Old 10-03-2012, 06:30 PM
Makc1kNYC's Avatar
Sorry if I ask this, but what is +2 timing? I never got that... lol
Old 10-03-2012, 08:45 PM
Timing refers to the event when the piston makes contact with the spark plug in your engine cylinder, which is also known as top dead center (TDC) if I'm not mistaken. At zero timing adjustment, the spark will ignite when the piston reaches TDC.
Advanced timing is when the spark ignites before the piston reaches TDC. As the piston moves in the engine, air is compressed and such. +2 timing advance ignites that volume of air and fuel at a point where the compression allows for higher power gains. I'm not sure if this has to do anything with piston head compression ratings though.
Old 10-03-2012, 08:49 PM
Usually for naturally aspirated motors, advanced timing is benefitial. I do +4 sometimes which is actually still in the safe timing range for the VQ35DE.
For turbo and other forced induction motors, I've read that retarded timing, say - 2 timing, is actually better since the motor is being forced with more air to compress instead of relying on the internal piston chamber pressures.
Hope that helps. Anyone, feel free to chime in.
Old 10-04-2012, 06:35 AM
theblackone3.5's Avatar
Does the bully dog work on the 4th gen maxima? Or just the apexi vafc2 for our cars?
theblackone3.5 is offline
Old 10-04-2012, 06:52 AM
Fundem's Avatar
What performance increases do you notice at +2 and +4? Is it good enough to spend the money? Better throttle responce, more HP ...etc
Fundem is offline
Old 10-04-2012, 01:42 PM
BoldMax's Avatar
Can somebody attach a picture
BoldMax is offline
Old 10-04-2012, 04:42 PM
Sharper throttle response. A nice kick at low rpms and a definite harder pull in the higher revs. Definitely can feel more G forces with the +4 timing.
Can't measure the hp. But the butt dyno does show results.
Not sure if it'll work on older gen maximas. You may need to check their site.
Is it worth the money? For $300, its not bad. It's a decent and lesser alternative to the much more expensive UpRev.
Old 10-05-2012, 05:23 AM
Fundem's Avatar
Where did you get it for $300? I saw $450-$500+..
Is it easy plug and play?
Fundem is offline
Old 10-05-2012, 09:32 AM
I got mine from Amazon. And my friend gave me present for a $50 gift card at the time. Lol.
Old 10-08-2012, 07:40 AM
CubbieBlue28's Avatar
Are you guys noticing an impact to MPG?
CubbieBlue28 is offline
Old 10-08-2012, 11:05 AM
No impact on mpg really. I get 20 in the city and 26 on the highway goin 70ish.
I want to note that timing advance doesn't give more hp overall, it just shifts the powerband up. Meaning more hp at lower rpms.
Old 10-08-2012, 01:19 PM
BoldMax's Avatar
Does it have to live in the car? Can i plug it in re-program and remove it?
BoldMax is offline
Old 10-08-2012, 01:36 PM
I have the wiring installed in my car. Just a plug into the OBD port and into the fuse. I tucked the wiring back under the dash so you can't even see it.
You don't need to keep the tuner unit always connected. I keep mine in the glove compartment for when I feel like doing a quick "reprogram".
Old 10-08-2012, 01:37 PM
It's not always live. You can keep it live to monitor things... But I just use it periodically to adjust my timing from time to time. So much time!! Haha.
Old 10-13-2012, 01:29 PM
4 Maximas and counting
philpoe's Avatar
In theory, could a piggyback like this advance timing at the lower RPMs, then advance it less as RPMs increase to get more power "under the curve"?
philpoe is offline
Old 11-18-2012, 11:44 AM
Nah.. timing is advanced throughout the entire powerband.
On older cars, timing is changed mechanically affecting piston position and spark ignition. I dont think it is possible to achieve multiple types of timing while the car is in motion.
The GT Tuner does not allow any multiple timing change over certain RPM ranges.
Old 05-22-2013, 06:56 AM
Fundem's Avatar
I saw 2 on their site... which one are you guys going with and why, the Watch dog or the GT?
Fundem is offline
Old 05-22-2013, 04:40 PM
CorollaULEV's Avatar
Anyone wanna take a stab at WHY the spark timing is so precisely set where it is? I.e., why Nissan would not have just advanced the timing curve by 2º or 4º BTDC more than what they did?
CorollaULEV is offline
Old 05-22-2013, 08:59 PM
trailer54's Avatar
I've been wanting to get one of these eventually!!
trailer54 is offline
Old 05-22-2013, 09:30 PM
Jam_Roc's Avatar
A possibility could be fuel octane.
Jam_Roc is offline
Old 11-03-2017, 08:00 PM
Jesse nissan's Avatar
Nissan Maxima 2016 issues with tuner
So I have a 2016 máxima and I bought a bully dog gt platinum gas tuner for some reason it won’t let me load the tune. The tech line said I need to maintain my voltage at 12.9 to 13.1 has any one had this issue and what did you do to fix it?
Jesse nissan is offline
Old 11-04-2017, 09:29 AM
Richard66's Avatar
The web site says to hook up a trickle charger to the battery to maintain the necessary voltage, and make sure all of your other electronics is turned off.
Richard66 is offline
carid
09-17-2015 05:00 AM
Adoubi21
Dyno Discussion and Slips
09-07-2015 09:34 AM
PSU09MAXIMA
08-28-2015 12:47 PM
Quick Reply: Bully Dog GT Gsa Tuner
