Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   7th Generation Maxima (2009-2015) (https://maxima.org/forums/7th-generation-maxima-2009-2015-78/)
-   -   09 maxima won't start (https://maxima.org/forums/7th-generation-maxima-2009-2015/660552-09-maxima-wont-start.html)
Disco lizard Jan 15, 2013 03:36 PM
Hey guys I have an 09 maxima that won't start. I'm getting obd ii p0603. I have had a tech come out and say the computer does not need to be programmed and the mech looked for broken wires and found none. Anybody has any suggestions.
PSU09MAXIMA Jan 15, 2013 03:46 PM
Maybe the dreaded steering lock issue there are threads here on it
Disco lizard Jan 16, 2013 09:00 AM
Thanks for the reply will look into it
Disco lizard Jan 16, 2013 11:42 AM
I checked don't think it's a steering wheel lock issue. I am able to press the start button and the car will crank but will not start.
I'm wondering if there is an issue with the security system, anyone know how I can tell if it is.
lightonthehill Jan 16, 2013 04:04 PM
I'm not an expert in this area, but I would think that if this was a security problem, the car would do nothing when you pushed the start button.
When you say the car will crank, do you mean the battery turns the engine over, but the engine does not start (fuel/ignition problem), or you just hear a rapid clicking noise (battery/electrical)?
Ghozt Jan 16, 2013 05:34 PM
have you tried testing/replacing the battery?
Disco lizard Jan 17, 2013 06:17 AM
Thanks for the reply guys, yes the engine cranks/ turns over but no ignition. I've even changed the crank sensor.
Also it's a brand new battery.
zoemayne Jan 17, 2013 03:41 PM
could be a defective battery did this start hapening before the new battery? what recent changes have you had? need more symptoms etc.
lightonthehill Jan 17, 2013 11:03 PM
Won't be a battery problem. When the battery gets weak, pushing the 'START' button
will not turn the engine over, but simply result in a clicking noise.
sloaphone Jan 18, 2013 12:09 AM
good, think that if this was a security problem, the car would do nothing when you pushed the start button.http://www.maxin.us/imax/images/6.gif
Disco lizard Jan 18, 2013 05:12 AM
Hey guys I spoke to my mech yesterday and he said to me that he has discovered that he is not getting a Pulse( not exactly sure what this means) and therefore no ignition.
He is still troubleshooting.
Could still use some insight.
Also we are no longer getting the p0603 code.
zoemayne Jan 18, 2013 06:19 PM
computer does not need to be programmed/Pulse??????
Well i think you should take your car somewhere else or at least get a diag at the dealer.... the best thing you can do is know a nissan dealer mechanic they often times have their own garages.
Disco lizard Jan 25, 2013 04:24 AM
Just an update, seems like I have to buy a new computer. I'm changing the bcm, PCM immobilizer and key fob from a salvage vehicle that runs. Does anyone know if there will be an issue/conflict with the transmission computer.
MaxFrost2011 Jan 26, 2013 06:48 PM
Damn, what did you do to screw up the ECM? I found this link. http://www.brakeandfrontend.com/issu...ontentid=92797
Do you have a code reader to clear code?
Disco lizard Jan 31, 2013 06:24 AM
Hey guys just an update, I got the vehicle started. There was and issue with the wire harness going to a cam positioning sensor.
Unfortunately i now have a complete computer set up that I don't need.
