Sponsored by:
Sponsored by:
Stereo question
Old 08-08-2013, 08:50 PM
BigMurph's Avatar
Stereo question
Im am currently in the process of building a sound system and was wondering if i needed to replace my stock head unit. Its just the basic head unit.
BigMurph is offline
Old 08-08-2013, 09:16 PM
MaximaDrvr's Avatar
I would use a processor like the JL cleansweep or something similar.
You can replace the HU, but some functions of the car will probably be lost.
MaximaDrvr is offline
Old 08-08-2013, 11:06 PM
Quinn'sMax's Avatar
What model do you have? If you have the S model like I do it would be better to change out the head unit.
Quinn'sMax is offline
Old 08-09-2013, 03:58 AM
Envymynissan's Avatar
You don't have to, but if you want better sound quality this should be at the top of the list.. It depends on how far you want to go with it. If you are adding subs only you can buy converters to install the amp. The headunit will have a dedicated sub out channel, and equalizers to get the most out of your speakers.
You will also be able to stream with bluetooth. You could add a backup cam, nav, you could run apps from your phone on the head unit... What are your plans?
Envymynissan is offline
Old 08-09-2013, 07:00 AM
BigMurph's Avatar
Thanks, I have the SV model. What I have so far are 2 kenwood 12's and 2 amps to power them. Right now all i want to do is get those hooked up then down the line I plan on eventually replacing the head unit and upgrading the factory speakers but for now i just want some boom.
BigMurph is offline
Old 08-09-2013, 07:13 AM
MEINEKEMAX's Avatar
check out audiocontrol.com they have what you need. Cheaper in most cases than JL Cleansweep
MEINEKEMAX is offline
Old 08-11-2013, 06:34 PM
20_Maxima_10's Avatar
audiocontrol LC-2...... will take care of the bose system bass drop off after you get passed half volume.....done
20_Maxima_10 is offline
Old 08-12-2013, 09:39 AM
II KRUCKUS II's Avatar
Agreed!! Tapped mine into the rear deck speakers and works like a charm!
II KRUCKUS II is offline
Old 08-12-2013, 02:25 PM
09max_sv's Avatar
I've used this recently and it works great, you don't have to search for the "remote" wire, as it auto sense the signal from the rear 6x9 and turns on the amp..
Though I have a questions is it work buying the extra remote bass **** with this unit ?
09max_sv is offline
Old 08-12-2013, 08:56 PM
I always say yes when you're working with a headunit that doesn't have an individual sub control. So I would def pick one up for either the LC-2 or if your amp has one.
Old 08-13-2013, 05:12 AM
Quinn'sMax's Avatar
I had the audiocontrol lc6i hooked up before I went aftermarket and it worked really good.
Unclejunebug
04-02-2016 05:42 AM
Stagnet04
10-11-2015 08:16 PM
sliptap
09-30-2015 05:57 AM
Socalstillen
09-26-2015 12:01 PM
Quick Reply: Stereo question
