Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   7th Generation Maxima (2009-2015) (https://maxima.org/forums/7th-generation-maxima-2009-2015-78/)
-   -   Buying 19's.. Will These Specs fit? (https://maxima.org/forums/7th-generation-maxima-2009-2015/676874-buying-19s-will-these-specs-fit.html)
ABOMBZ Apr 9, 2014 12:42 PM
Looking to get some aftermarket wheels. I'm not sure if the Bore is correct for 2012 S Model? Specs below, will these wheels fit and if not what would need to be modified to do so?
Name:
LFA STYLE
Size
F:19x8.5"
R:19x9.5"
Bolt Pattern
5X114.3mm
Offset
F:35mm
R:38mm
Color: HYPER SILVER
Hub Bore Size: 73.1MM
http://api.viglink.com/api/click?for...%20Forums&txt=
dr_2010SV Apr 9, 2014 08:05 PM
Nice looking. Are these the LFA replica Ebay rims?
I believe Maxima wheels have a 66mm hub bore. See if they have appropriate sized hub rings.
MaximaDrvr Apr 10, 2014 03:17 AM
Those will bolt on with no problems. You will only need hub rings, as mentioned above.
ABOMBZ Apr 10, 2014 07:22 PM
I called them and the tech said that they need to be bored out? If they just need spacers than I may have found my wheels! Hyper Silver LFA Replica Wheels!
MaximaDrvr Apr 10, 2014 07:42 PM
Those are 73.1. We have 66.1
You will need to order hub rings.
You may need narrower lug nuts, can't tell from the picture.
ABOMBZ Apr 10, 2014 09:16 PM
Any idea what size hub rings I would need and the best place to get them?
Racerbox77 Apr 11, 2014 03:21 AM
Ebay
ABOMBZ Apr 21, 2014 06:48 AM
Now considering the 20" Inovit Speedys. Will be looking to Polish the inside of the silver wheels Hyper Silver look.
Thoughts?
http://inovit.com/Upload/FCK/201402251433363179514.jpg
Offset:
35
Rim Width:
8.5
Rim Diameter:
20
Number of Bolts:
Rim Brand:
INOVIT WHEELS
Bolt Pattern:
5x114.3
Hub Bore:
73.1
Rim Structure:
One Piece
MaximaDrvr Apr 21, 2014 11:46 AM
They won't look quite like what you have pictured. Not nearly as concave with 8.5 et35.
They will still fit with no problems.
ABOMBZ Apr 21, 2014 12:29 PM
Will these need Hub Rings?
MaximaDrvr Apr 21, 2014 01:25 PM
Yes.
The maxima has a 66.1 hub bore. These have a 73.1 bore.
You need these:
http://www.ebay.com/itm/4-Hubrings-73mm-73-1mm-Wheels-to-66-1mm-Car-Hub-fits-Nissan-Infiniti-Hub-/331092955834?pt=Motors_Car_Truck_Parts_Accessories&hash=item4d16ad92ba&vxp=mtr
