2010 Maximum Backup Camera
Question where to begin or just bring to Nissan ?
Backup Camera is AT TIMES ,not working properly, At times it works fine others it's hit and miss I always have the lines red ,green and yellow but no view it seems it happens mostly when car is in garage and weather is humid or damp or rainy I THINK !
Other times camera view and lines are fine.
I noticed there are wires that are enclosed at top hinged area of trunk, I think wires from screen must come thru either left ( driver side ) or right ( passenger side ) ?
How to figure this out question, is it loose wire ,defective camera or a broken wire ?
How much is a new camera ? Thanks in advance , Mike
Did you have or perform any radio/speaker or modification work to the system? Or if you're not the original owner maybe the PO did? I ask because what you describe about the conditions you've noticed it acting up, (humid, damp or rainy) leads me to believe that the system wiring was opened up at some time and the moisture is getting into the connections.
It may be something as simple as unplugging a connector, spraying the terminals with lubricant and reconnecting them. Or you could have an exposed wire that's getting wet in the conditions you stated earlier and the dampness is causing the interference.
I don't know what an OE system costs but from my experience your problem sounds like an easy fix. I would go to a stereo install shop and have them check it out if you're not confident enough to do it yourself.
willco
05-04-2016 06:12 PM
jholley
03-11-2016 06:20 PM
