Constant squeaking on Racingline RASB
I installed a Racingline rear anti sway bar last year. since then I have had to have it lubricaged three times in order to stop an annoying squeaking. has anyone else had this happen? Is there a better RASB out there then the Racing Line?
Correct me if I'm wrong, but I don't think that Energy Suspension makes anything for the 7th gens. I looked for prothane bushings when I replaced my RSB, but I could not locate any options available other than OEM bushings.
I also ended up using the OEM bushings for years without any issues. I took off the ones that came with the Racingline RSB soon after the install due to noise.
There is not a better bar, but there are better bushings. SS has been stated,mother OEM can be used, or you can modify the holders and install zerk (grease) fittings if you are mechanically inclined.
These are compatible with the Racingline RSB. A member on the FB group has purchased them and used them on his car. I'm about to order a set myself as my RSB is squeaking pretty badly.
https://www.amazon.ca/dp/B000CN7BTS/..._mu.BxbQSTBEDT
jeffrop
09-02-2016 06:38 PM
follyburr
04-12-2016 11:12 PM
