Sponsored by:
Sponsored by:
Help!! Slip indicator light!!
Old 05-11-2016, 02:27 PM
Angieholloway@ymail.com's Avatar
I have a 2012 Nissan Maxima. The check engine light is on. And while driving the slip indicator light comes on. And it jerks hard when pressing gas. Like it's not getting fuel. If you slam on the gas. It does nothing. Only happens when the slip light comes on.
Angieholloway@ymail.com is offline
Old 05-11-2016, 07:45 PM
Maxgig's Avatar
Break out your owners manual, I vaguely remember reading something in it about a certain issue if the slip indicator light came on. I can't check mine at the time to verify or confirm my suspicion.
Maxgig is offline
Old 05-12-2016, 07:23 AM
Willing to learn
oldngivout's Avatar
If the check engine light is on, reading that code will greatly help in the diagnosis of your issue.
Any auto parts store should be able to do that for free.
oldngivout is offline
Old 05-12-2016, 07:54 AM
Yea went to auto store the code came up. And it has five different things with that code.....
Old 05-12-2016, 04:12 PM
MaximaDrvr's Avatar
If you actually provide the code, we can offer more help.
MaximaDrvr is offline
Old 05-12-2016, 05:37 PM
This is the image from what he gave me. But I think the code is. P0101
Old 05-12-2016, 06:12 PM
MaximaDrvr's Avatar
Mass Air Flow sensor code.
Do you have an aftermarket intake, or stock? How many miles?
Old 05-12-2016, 06:18 PM
It is stock. And 60,000 miles
Old 05-12-2016, 06:21 PM
Nopike's Avatar
Did the problem just start out of the blue or did someone work on the car? Maybe they disconnected the MAF sensor?
Nopike is offline
Old 05-12-2016, 06:23 PM
Just started out of blue.
Old 05-12-2016, 06:25 PM
Nopike's Avatar
Is it possible someone messed with any of the following recently?
Check the following for connection.
• Air duct
• Vacuum hoses
• Intake air passage between air duct and intake manifold
Nopike is offline
Old 05-12-2016, 06:29 PM
Nopike's Avatar
You would need to check the items I mentioned. Not sure of your troubleshooting ability but here is a link to the FSM. http://www.nicoclub.com/FSM/Maxima/2010/EC.pdf
If none of that helps you will probably need to take your car to a mechanic.
Nopike is offline
Old 05-12-2016, 06:30 PM
• Air duct
• Vacuum hoses
No nobody messed with it?
Old 05-12-2016, 06:35 PM
Nopike's Avatar
I did a search of P0101. Maybe this information will help you.
https://maxima.org/forums/search.php?searchid=4203583
Nopike is offline
Old 05-12-2016, 06:37 PM
Nopike's Avatar
Maybe your dealer can help, someone stated:
I just called my dealer and they said that it is covered under 8 year / 80k (ballpark) warranty for ECM reprogram. I will make an appointment and keep you guys posted.
Nopike is offline
Old 05-13-2016, 03:01 PM
Ok .... So I cleaned the MAF sensor worked for a min. Light came back on! So then I bought a new sensor replaced it. Worked light came back on. When the slip light comes on. It won't even rev up past 2500. And sounds like it's going to fal apart!!!
Old 04-04-2017, 07:19 PM
Dannyman91's Avatar
Hey there sorry to bother you but I'm having this same exact problem....
How did you solve your issue?
Dannyman91 is offline
Old 04-05-2017, 07:25 AM
Richard66's Avatar
Check your brake fluid level. Low brake fluid and/or worn brake pads will trigger the slip indicator warning.
Richard66 is offline
Old 04-05-2017, 01:31 PM
Les7311's Avatar
Originally Posted by richard66
check your brake fluid level. Low brake fluid and/or worn brake pads will trigger the slip indicator warning.
x2
Les7311 is offline
Old 04-05-2017, 01:32 PM
Les7311's Avatar
That is correct.
Had mine done at 79,700 miles by dealer when the problem started
Les7311 is offline
Old 05-05-2017, 02:45 PM
Mymax11's Avatar
I have the same issue, with it going into limp mode. I would also check your CVT fluid and/or have it replaced. When fluid gets too hott it puts in limp mode if you pull over n shut car off for a min or two it should go away for a while. The brake fluid thing is deff true as well.
Mymax11 is offline
Old 05-30-2017, 09:48 AM
Mymax11's Avatar
So after months of dealing with tranny limp mode I checked fluid nice n clean and topped off. I didn't get why it was happening just started thinking well guess I got 1 of the junk cvt transmissions. So before I took to a transmission shop I put a transmission cooler on and have not had issue since figure I'd share that bc I know how frustrating it is and dangerous it is.
Mymax11 is offline
~V~max
06-10-2016 06:22 PM
Maximum808
04-26-2016 02:48 PM
yosbel_11@yahoo.es
04-12-2016 09:46 AM
Quick Reply: Help!! Slip indicator light!!
