HVAC blend door actuator
I need a detailed diagram on how the arms fit on the blend door and the actuator. I removed the actuator and the arm in behind fell out. Almost impossible to see up in the tight area. 2009 Maxima...
you can find the blend door actuator by looking up above the gas pedal, small black box with white plastic rod coming out of it. Check it by moving your mode button while watching the arm move the vents
