TPMS Dash Light
Hi All,
I just changed my summer tires to my winters tires (summers have the tpms sensors) and the tpms indicator came on before the change (small triangle indicator on dash). Tire pressure was low . Is there any way to reset this without having to put the summers back on, setting proper tire pressure and then changing back to winters? All help is appreciated, Thanks |
I don't know the answer to your question as I never change over to winter tires. You got the TPMS light because one of your summer tires was low on pressure. If you clear the code by putting the summers back on. You will again get that light because the computer will sense no tire pressure because of loss of signal with your winter tires only this time the warning light will probably be flashing.
or a bad sensor
Originally Posted by capri66
(Post 9162626)
Hi All,
I just changed my summer tires to my winters tires (summers have the tpms sensors) and the tpms indicator came on before the change (small triangle indicator on dash). |
(Post 9162626)
Hi All,
I just changed my summer tires to my winters tires (summers have the tpms sensors) and the tpms indicator came on before the change (small triangle indicator on dash). Tire pressure was low . Is there any way to reset this without having to put the summers back on, setting proper tire pressure and then changing back to winters? All help is appreciated, Thanks If your winter tires don't have TPMS sensors at all, then you will be staring at tpms warning until you either put summer tires on or install tpms sensors into winter tires. Every time you start the car, it reestablishes contact with TPMS sensors, its a dynamic system. |
© 2024 MH Sub I, LLC dba Internet Brands
