Doors unlock in "Park" position?
From an earlier poster
It does not have the option to auto unlock the doors when you put it in Park, but it does have the option to auto unlock the doors after you turn the engine/ignition off.
AUTOMATIC DOOR LOCKS
● All doors lock automatically when the vehicle
speed reaches 15 MPH (24 km/h).
● All doors unlock automatically when the ignition
is placed in the OFF position.
The automatic unlock function can be deactivated
or activated. To deactivate or activate
the automatic door unlock system, perform
the following procedure:
1. Close all doors.
2. Place the ignition switch in the ON position.
3. Within 20 seconds of performing Step 2,
push and hold the power door lock switch to
the position (UNLOCK) for more than
5 seconds.
4. When activated, the hazard indicator will
flash twice. When deactivated, the hazard
indicator will flash once.
5. The ignition switch must be placed in the
OFF and ON position again between each
setting change.
When the automatic door unlock system is deactivated,
the doors do not unlock when the ignition
switch is placed in the OFF position. To unlock
the door manually, use the inside lock **** or the
power door lock switch (driver’s or front passenger’s
side).
The automatic lock function can be deactivated
the automatic door lock system, perform
1. Close all doors.
the position (LOCK) for more than
5 seconds.
setting change.
1. Close all doors.
5 seconds.
setting change.
side).
1. Close all doors.
5 seconds.
setting change.
DcMaN
06-03-2005 03:54 PM
chrisZ
12-21-2003 10:19 PM
pjonkheer
09-12-2002 08:00 AM
