whining while turning steering wheel (stationary) and driving and also idling
Old 05-13-2018, 02:08 AM
irfan6163's Avatar
There has been a whining while turning steering wheel (stationary) and driving and also idling for sometime now. Checked for power steering fluid and it was below the low line, so topped that up. But still the sound does not go away. Also, when I turn the steering all the way to the end, I hear a grinding sound on both directions.
Nissan Maxima 2013- SR Sports Package 145000 Kms
File Type: zip
irfan6163 is offline
Old 05-14-2018, 06:59 PM
Nissanfinatic's Avatar
I am having the same issue did you figure it out yet?
Nissanfinatic is offline
Old 05-14-2018, 07:00 PM
I have been doing a lot of research and I have found tons of answers and I don't want to go to the dealership
Old 05-15-2018, 01:07 AM
irfan6163's Avatar
went to a local workshop and it seems it was a bad P/S pump and pressure hose. Replaced the hose and got the pump repaired.. Works like a charm and the sound is no more. Also, the steering is now smooth.
Old 05-15-2018, 06:17 AM
How much was it I have dumped a lot of money on this car this year and I just want it to be perfect.
Old 05-15-2018, 06:21 AM
irfan6163's Avatar
The P/S pump is expensive and thats why the mechanic suggested a repair. The hose assembly costed around AED 500 and the pump price here in UAE is AED 850. But before you do all this just check if the P/S oil level is going down.
Old 05-15-2018, 08:36 PM
Well, luckily my 2014 is still under warranty, so I don't have to pay for it. I might have a small deductable, but it will be worth it. I cant wait to get this fixed after this I will have some minor cosmetic issues to take care of, but it will be set. I like my car, but the **** hit the fan this year. I will admit I have put some miles on it, but this should not be happening.
Old 05-16-2018, 12:43 AM
irfan6163's Avatar
It's good that the car is still under warranty. Mine had just 3 yrs warranty from the dealership which expired in 2016. I also got another issue that I need to get fixed soon. Car steering vibration above 100 kmph. Balanced the tires twice, before getting new tires and after but the vibration does not seem to go away. Any thoughts ?
Old 05-16-2018, 03:36 PM
Richard66's Avatar
Did you get a four wheel alignment? Did you check for a Bent wheel? If yes on both try a another balance at a different shop.
Richard66 is offline
Old 05-16-2018, 05:10 PM
Look on the inside of your wheels you might have a slight bend that throws you off. I did four wheel alignment also and camber bolts.
Old 05-19-2018, 12:07 PM
It turns out my problem was not the power steering it was two defective motor mounts bearing, and some other stuff luckily it was all under warranty the only thing I paid for was a power steering flush.
Old 05-19-2018, 12:40 PM
irfan6163's Avatar
such a releif when its under warranty. I still have to get my car tires aligned and balanced. Will keep this thread posted.
Old 05-20-2018, 08:24 AM
If they recommend camber bolts do it when you are doing your allignment; they made a huge difference.
Old 12-28-2018, 10:01 AM
Nestorsh's Avatar
That sound was because bad motor mounts?
Nestorsh is offline
Old 01-01-2019, 01:24 PM
Mymax11's Avatar
My 11’ does that only when I first start it when it’s cold out. (Upstate New York) but goes away way within a few minutes.
Mymax11 is offline
gavin68
10-04-2012 07:15 PM
|Bijan|
09-21-2004 10:18 PM
FormorAccordMan
05-28-2003 05:45 PM
DaBoxSE
12-13-2000 07:08 AM
Quick Reply: whining while turning steering wheel (stationary) and driving and also idling
