Sponsored by:
Sponsored by:
An open intake tube?
Old 09-10-2018, 10:41 AM
Ultra's Avatar
Did air filter replacement yesterday and ran across a plastic tube that hooks up to and under the air intake accordion. Cannot seem to find this part name anywhere on Nissan'S diagrams? It goes back under the throttle body, under the intake plenum and just sucks in unfiltered air? Am I missing something? Felt around back there for like an hour. Don't see anything that would hookup on the other end of that tube. Is this unmetered air?
Does anyone know the part name?
Ultra is offline
Old 09-10-2018, 12:27 PM
wildcat08's Avatar
I think what you are describing is the 'sound generator'. Check out this thread for more info: Plastic Tube Left Over From OEM Intake
wildcat08 is offline
Old 09-10-2018, 06:03 PM
Ultra's Avatar
Hi wildcat.
Thanks for reply.
This is indeed the 'tube' I found.
Funny about that thread, people can't really tell if the air gets sucked in or blown out of this tube.
I may try a filter of sorts and leave it on instead of capping it off.
Just totally weird as it seems to allow for unmetered air (to enter Or exit) it's unmetered by MAF. So how is air mix calculated accurately?
Idungetit.
Thanks again for the share.
Ultra is offline
Old 09-11-2018, 05:58 PM
Tutti57's Avatar
I want to take a look at one now. There is no way that part could be after the MAF sensor letting that much air in. Most cars use the MAF, TPS, MAP, ECT, O2, to control mixture.
Tutti57 is offline
Old 09-11-2018, 07:30 PM
Ultra's Avatar
That's what threw me for a conceptual loop.
It is open. Might be 'static' air there due to relationship with the air flow from the air box?
I'm idling fine. But this puts questions as to what really happens if it is blocked off? What if main intake gets partially blocked? Does it now draw air from the resonator? What if air is pushed through and out the resonator? Does that mean the ecu and MAF accounts for the air loss in some way so if you block it off you mess up your fuel/air? Sooo many Q's.
Ultra is offline
Old 09-12-2018, 06:39 AM
wildcat08's Avatar
The tube is closed, as in it's not pulling outside air in after the filter. I removed mine a few years ago and capped it off. It doesn't effect how the car runs one way or the other.
Old 09-12-2018, 08:43 AM
zappasian's Avatar
Someone on a other forum mentioned that there is a diafragm in the middle like a Passive reflex in a home speaker..
zappasian is offline
Old 09-16-2018, 12:34 PM
Tutti57's Avatar
We finally got one in the shop yesterday and I took a look while checking the air filter. It does have a hole in the intake tube where it attaches but there has to be something blocking off the air like other people mentioned. I wanted to take it apart and look in there but that's not a good move on a customer's car!
Tutti57 is offline
dr-rjp
11-16-2007 11:29 AM
da God
09-23-2007 10:18 PM
ghostridden
01-25-2005 12:38 PM
4thgradedropout
10-03-2004 09:21 PM
natricks1
04-23-2002 09:55 PM
Quick Reply: An open intake tube?
