2011 Nissan Maxima shifting issue
the issue I’m having with my car is... I bought it back in 2015 at 56k miles and now to date it’s at 111k miles. I’m getting trouble code “p1777” as google says it’s a step motor relation. I think it’s cauaed by the insane cold weather i had in my city, New York, this past Monday and I drove the car and as driving I realized the driving experience and feel had no difference from regular D or Manual mode where I would down shift and upshift myself with the paddle shifters. My car feels it’s stuck on first gear or soemthing. I get no bad jerks or anytging it switches between PRND normally and when in manual mode I can shift form 1-6 and down 6-1 but the revs aren’t matching the downshifting or the upshifting. Just feels it’s only on one gear. I tried to put my cruise control on yesterday but it started flashing/blinking which I’ve never seen before. But today I tried it and it ddint flash/blink although it didn’t “set” either. I checked my tran there is no leak so I haven’t seen an puddles underneath the car after parked. The Tran oil level on the dipstick is just a little bit under the “Hot” mark. If anyone can please help ! Much appreciated ! I posted a thread before but idk what happen to it. Thank you. Also the las time I had my tran oil flushed was back In June 2017 which was when I had put 40-50k miles on the car since purchasing because I hid a bad bump and cracked my transmission oil pan which I had replaced with the OEM on from Nissan dealership.thank you !
It's well known that machine pressure flush is harmful for any automatic, let alone a CVT.
well I had cracked my transmission pan cuz of a bump so had the old oil drained and then new pan installed with new oil from the dealership . No machine pressure at all
See this video, may help
https://www.youtube.com/watch?v=ZDVUDfcTG-g
https://forums.nicoclub.com/2009-nis...e-t397225.html
https://www.nicoclub.com/FSM/Maxima/2009/
https://www.nicoclub.com/FSM/Maxima/2011%20Maxima/
Google works wonders !!! See TM section
yeh found it, but doesn’t show an exact picture of the step motor itself just tells the diagnoses and a lot of technical stuff. Thanks for that. But what are the chances of the 2009 having the same layout as a 2011. However I did order a new remanufactured valve body which comes In Monday and then gonna finally replace it. The seller says it’s works 100% , doesn’t need programming and it’s “plug and play”. From valvebodyfactory .com
Maximamo
01-25-2019 08:26 PM
Janiporo
09-23-2013 08:11 AM
