Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   7th Generation Maxima (2009-2015) (https://maxima.org/forums/7th-generation-maxima-2009-2015-78/)
-   -   BOP's (https://maxima.org/forums/7th-generation-maxima-2009-2015/703857-bops.html)
Jluna1994 Mar 8, 2019 07:09 PM
BOP's
I know I'm late on this subject and should have taken the opportunity when I had it. But if possible where can I find the 7th gen block off plates and intake spacers? any help is greatly appreciated
freezer Mar 9, 2019 08:00 AM
You want less power?
mahanddeem Mar 9, 2019 09:42 AM
Snake oil.
I'd say keep maintenance for the car to run peacefully.
danalmsa Mar 11, 2019 05:03 AM
Personally, the BOP resulted in loss of power. Specially installing on the passenger's side.
Spacers, couldn't tell, so at the end possibly not worth it, though we'll see if the upRev tune will make it work.
If you want a bit more, try the y-pipe with exhaust. Then get yourself an OBDC connector (Elm327) and buy the very inexpensive app called CVTz50, which was made for Nissan's. Apart from useful for monitoring the CVT transmission, it allows you to adjust timing up to 2 degrees.
Jluna1994 Mar 11, 2019 06:13 AM
Badass thanks for the reply
