Front signal fast blink
hey fellas, need a lil help here. I own an 09 sv sport and for a few now the right front signal light fast blinks and at times goes back to normal after driving for a while then goes back to fast blinking. I checked all fuses, replaced all signal bulbs front and back. Even replaced the signal socket cause it was cracked on the side and this light still does it. Can someone chime in with some advise, thanks in advance for the help |
Could be the flasher starting to go bad I would replace that and see if that works for you and go from there.
You've got a bulb out somewhere or a secondary filament in a dual filament bulb that's out.
That too is possible..
Thanx for the replies guys. Where is the flasher? I thought these cars didn’t have one, bulbs? I changed all the turn signal bulbs front and rear and every bulb in the car seems to be working. When I took out the tail light there were about two extra bulbs in it. Maybe one of them? Thanx guys again |
No problem glad to help, Check out the 2 extra bulbs in the tail light just in case, The flasher relay if it's equipped with one would be located under the drivers side dashboard.
© 2024 MH Sub I, LLC dba Internet Brands
