Air condition problems on my 2010 maxima
Ok guys and gals, I just recently put a new ac compressor on my car. Later noted it was not cooling like it should. For about 10-15 minutes it would run warm then get cold. Was told it needed more freon (excuse my spelling) so we added another can with no problem. Now the car has like surges when running with the ac on. You can see the rpm hand go up and down just a little and can also feel it in the power of the car. Also when parked and running it does the same thing and now it's just blowing warm air. Please please please any ideas or suggestions would be greatly appreciated.
Originally Posted by Karen Guy
(Post 9203761)
(Post 9203761)
Originally Posted by VeeQue35DE
(Post 9203769)
What did you change out when you serviced your compressor and how was it serviced? Did you add the proper weight PAG oil to the compressor? Some compressors have a warning on them that says you have to drain the assembly oil and add the correct oil before installation. Did you change the accumulator / receiver drier? Did you change the TXV (Thermal Expansion Valve)? Did you change out the condenser? If you touched the heater, did you bleed the system? Did you touch the evaporator core? You need to list the procedures, parts, and problem so you can make a diagnostic flow chart to resolve the problem.
Yeah, what he said. Til then, no one will ever know. And fire whoever told you to just dump more "freon" in it. Despite the fact that it may be likely that your low pressure switch is tripping on and off, whoever refers to refrigerant as "freon" in this day and age doesn't have a clue about anything. Stay away. Beyond that, the answers to VQ's questions would be a great start. |
(Post 9203769)
I'm hoping everything was done properly. It was changed at a shop so I'm not sure how to answer any of your in depth questions. I am just curious as to what the problem could be now. Will be taking it back to the shop to see what is going on. Just dont want to be jerked around. |
(Post 9203799)
Originally Posted by User1
(Post 9203800)
Let us know how it goes at the shop.
© 2024 MH Sub I, LLC dba Internet Brands
