Quick! Will these wheels fit???
Found a good cheap deal on these. Don't know about the offset and width?
Manufacturer: RTR Style: RTR Size: 19x9.5 Finish: Dark Charcoal Placement: Front or Rear Centercap Size: Included Back Spacing: 6.5" (165.1mm) Offset: +33mm (1.3") Bolt Pattern: 5x4.5" (5x114.3mm) Weight: 28 lbs Material: Aluminum |
The bolt pattern is good. Center bore needs to be 66.1 if its bigger make sure u get hub Centric rings. With that offset u might have to run a little camber its beyond +38et
© 2024 MH Sub I, LLC dba Internet Brands
