Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   8th Generation Maxima (2016-) (https://maxima.org/forums/8th-generation-maxima-2016-88/)
-   -   Lowering Springs (https://maxima.org/forums/8th-generation-maxima-2016/692833-lowering-springs.html)
im not gay but $20 is $20 04-07-2016 07:49 AM
Lowering Springs
If I'm not mistaken, most of you guys are using 7th gen max springs correct? When I go to Eibach.com, they state that the part # for the 2016 Max is 63115.140, which I cross-referenced as the same part # for the 2013-2016 Altima. Stillen's website states that to use the 09-14 Maxima springs.
Has anyone used Eibach's recommendations and used the Altima's springs? Part # 63115.140? And pictures of the drop if you have it please?
im not gay but $20 is $20 04-07-2016 07:51 AM
Also checked the struts and springs part # from Nissan, and each has different part #s. Doesn't show the 8th gens having same exact part # from the 7th gens and the altimas
Frasierts 04-07-2016 08:31 AM
https://cimg8.ibsrv.net/gimg/maxima....9c9e325f1b.jpg
I used the 63115.140's from Stillen.
im not gay but $20 is $20 04-07-2016 08:47 AM
The drop looks really nice. How much room do you have in the rear? Also, do you think getting wheels that would stick more flush with the fender by 1/2 an inch would rub?
Frasierts 04-07-2016 09:06 AM
Eibach states the kit is supposed to drop the car 1.5 all the way around, however, my front is 1.75 and rear is 1.5. I am looking at wider rims/tires for the rear, 1/2 inch would work.
im not gay but $20 is $20 04-07-2016 11:24 AM
Do your tires tuck under with 3 adults in the back of the vehicle?
A36-SR 04-07-2016 05:11 PM
1 Attachment(s)
I use 2012 maxima springs Attachment 8558
tc8510 04-07-2016 05:17 PM
1 Attachment(s)
Also using Maxima Eibach lowering springs.
luigibatista 04-07-2016 05:36 PM
I am about to order one from Stillen. Do I need an alignment kit.
im not gay but $20 is $20 04-07-2016 05:40 PM
Stillens website tells you to use the 09-14 maxima eibach springs, but eibach is saying to use 13-15 Altima springs. So torn but frasierarts drop looks like what I'm looking for. So I think I'm going to go with eibach a recommendation. Found the kit for $212 shipped.
luigibatista 04-07-2016 05:43 PM
I also wanted to know if the wheel tuck in when passengers are in the car.
mpbclutch33 04-08-2016 06:09 AM
I ordered mine last on EBAY. A guy had bought them for his Altima and never used them and decided to go with Coilovers. I got them for $180 shipped. Now just need to find time to install them. I don't think you will need a Camber kit. Its not that aggressive of a drop and they should be able to get you pretty close at the alignment shop
im not gay but $20 is $20 04-08-2016 07:46 AM
Below is a link of where to buy for $212.01 w/ free shipping. I've never ordered from there but they're giving it for a good price. I'm most likely going to order when I come back from a trip next week or so.
http://www.shockwarehouse.com/site/p...wrZ24BRC098fr-
OqnuMkBEiQAKQ9lgK8_KC48SGR_Z96d9Dm81Z1LmGKj8ZUrRZz AYN-gJV8aAu1O8P8HAQ
tc8510 04-08-2016 08:17 AM
Yea you definitely don't need a camber kit. I went to Firestone when they had the special and got lifetime alignments for $169, normally 2 n change.
Nguyen1 08-10-2016 07:14 AM
Stillens 16 maxima eibach claims 1-2 inch drop. Anyone got these know the height it lowered their max by? Thx
https://www.stillen.com/suspension/l....html?___SID=U
R1talin 08-10-2016 10:38 AM
eibach spring kit - Manufacturer Part #: 63115.140 - (Note: Avg. low 1.4"F and 1.0"R.) - i got approximately 1.5 in the front and 1.0 in the rear. with adult passengers the rear does not tuck.
https://cimg6.ibsrv.net/gimg/maxima....9d5ca6730a.jpg
Front Before
https://cimg0.ibsrv.net/gimg/maxima....acd382826c.jpg
Front After
https://cimg7.ibsrv.net/gimg/maxima....bd8bd69410.jpg
Rear Before
https://cimg9.ibsrv.net/gimg/maxima....8c454453ac.jpg
Rear After
https://cimg8.ibsrv.net/gimg/maxima....952bd729fe.jpg
https://cimg9.ibsrv.net/gimg/maxima....33dbd9c7ba.jpg
Nguyen1 08-10-2016 11:17 AM
Nice, your car is SR version? I believe those models are lower than rest stock.
R1talin 08-10-2016 11:39 AM
Yes, it's an SR. SR has different suspension components but i don't find any facts related to it being lower than any other model. Also, tire/wheels P245/40R19 and P245/45R18 are both the same height at 26.7".
If anyone else can chime in to the SR being lower stock that other models, please do.
bghouse 07-20-2018 09:44 AM
Pro kit on my 16 Max
Hey R1talin,
I know this is an old thread but wanted to ask you bout the drop in the rear on the pro kit not being the same as the front. I just installed mine last weekend, got my alignment yesterday & similar issue. Front dropped 1.5" but rear only .5-.6". Did yours ever settle? I'm waiting to hear back from Eibach tech on this but wanted to get feedback from other members.
trillzmillz 03-15-2019 11:57 AM
I like the look a lot man! how different was the ride? (comfort wise)... looking to choose between these or coil overs.
bghouse 03-15-2019 05:39 PM
IMHO, it is more sensitive to bumps but handling is tighter. I don't feel there was much loss in comfort. I just wish I didn't have to cut a bit off my rear springs to get the back even w/ the front but it was worth it, looks great now.
https://cimg7.ibsrv.net/gimg/maxima....b602c028c9.jpg
2000G6 03-15-2019 11:19 PM
I just installed the Eibach pro kit lowering springs and regretting it already. Purchased them through stillen, the Altima/maxima versions. When at speed wheels sound as though they’ll come through the hood upon hitting the slightest bump in the road. I’m on stock 18 wheels stock shocks stock tires. Any advice?
Nmax5150 03-16-2019 01:25 PM
Remove drop springs , install stock springs.. Fixed!
bghouse 03-19-2019 10:22 AM
I'd say before you swap back to stock, you should take it for an alignment & make sure the springs are set & pre-loaded correctly. That doesn't sound right w/ 18' wheels, it shouldn't be bottoming out like you are describing. You buy the 63115.002 springs?
© 2024 MH Sub I, LLC dba Internet Brands
