8th Gen Non-Bose System upgrade (Build)
#81
In my experience with my old altima I removed those on the dash and it was night and day the sound bouncing off the windshield. But of course each to their own. I also had a Pioneer AVH 8500 that gave more power than what I am sure this head unit does. I just gotta figure out what speakers to go with. This guy at a shop I go through is trying to talk be in to the Hertz brand.
#82
Those Hertz are serious, I checked them out after reading the latest posts here. I wonder if the mids would fit where the factory dash speakers are? I also wonder if those big tweeters would fit in the trim piece that covers the back-side of the rear view mirrors next to the A-pillar (that's where I put the 3/4" tweeters in my Maxima). Those cross overs look huge; it'll be hard to find a good place to hide them, especially on the passenger's side.
Tommie70, since you have that DSP unit, I'd think you'd be able to work with the delays and perhaps some subtle EQ to get really coherent sound where ever you decide to put the drivers.
Lots of pictures, please, Ricanpapi and Tommie70.
#84
#85
#86
So..... I'm not 100% done, nor am I 100% happy with the way some of it turned out, but It sounds pretty damn good. I replaced the Focal 2 way systems with the Hertz 3 Way up front, and Infinity Perfect 900 6X9 2 way components in the rear. also replaced the Boston Acoustics subwoofer with a Rockford Fosgate Punch P3 Sub.
#88
I lined the Doors inside and out, rear deck top and bottom, and the rear seat area with sound deadening mat. I used about 80 Sq Ft of the matting to do the job. I was able to reach most of the inside of the doors through the speaker openings. if you remove the black plastic speaker stand-off, you can get you arm in there pretty far. I had to be careful in some spots not to block anything important. They say that you don't have to cover every square inch, that its the mass that helps deaden the sound.
#93
i thought about putting the 3” in the dash, but the DSP would be changing the timing of the whole set, theres not a way for me to change the timing on just the 3” speakers. I think I have a plan, we’ll see.........I’m waiting for it to warm up a little before I go out there and start ripping everything out
Can you post some pictures of how you got the factory "grilles" in the dash off? I simply disconnected the factory dash speakers, but was never able to get the grilles off: I couldn't get them to move enough to come free before they hit the wind shield glass.
Are those the Hertz tweeters in the trim piece at the bottom of the A-pillar (that covers the back of the rear view mirror)? I didn't think such a big driver would fit in that little trim piece. My JL Audio 3/4" tweeters seemed like a tight fit, I wasn't confident even a 1" tweeter would fit there.
What sound deadening mat did you use? Is that DynaMat extreme?
#94
Where did you mount the Hertz crossovers? Oh, yeah, would love to see some photos of your car when everything is put back together again. I know all the details of your install will be covered up, but it would be good to see how everything looks. Did you change anything in the trunk (more amp channels)?
#95
I will be getting the crossovers mounted tomorrow, everything will be in the trunk. I will get pictures when I’m done. I used Noico mat from Amazon. Much cheaper than Dynamat and works great!
#96
#97
Thanks for that information. I will check Noico out. I've always mounted passive crossovers in the doors, too much wire to run back up to the front if the crossovers are in the trunk. I hope it goes well in your install. I'm about out of "hidden room" in my trunk with the JL Audio DSP units (FiX and TwK). I just saw on the JL Audio site the have new amplifiers that are similar to the Audison units: integral DSP. They have an 8-channel with DSP that is smaller than what my two 4-channel amps require. Would have been about the same price overall. Where was that before I started buying hardware last year?
#98
#99
Tommie70:
That's exactly what I'm doing: one amp channel per speaker. Now that I have DSP, I wanted to experiment with digital crossovers, delays for coherency and EQ. I do not plan to install a 3-way system in the front, but do want to have the rear door speakers, so I need eight channels for now.
I'm with you: if there is a ****, I need to be able to turn it, even if I never will. I like the JL Audio DSP units, all I need is a USB cable to connect them to my computer.
I also have a big sheet of foam: I get rattles from the rear deck. When I replace my rear speakers with actual sub-woofer drivers I'll fit a piece of foam between the rear deck and the plastic finisher panel.
I'm impressed you fit those big 1-1/8" Hertz tweeters in those little panels. I was worried that my 3/4" tweeters would barely fit. I guess I don't have to be so worried about tweeter size when it's time to replace my front speakers.
#100
Tommie70:
#101
I have two Rockford Fosgate Punch 400 amplifiers, so eight channels at 50W each. I don't listen at ear bleeding levels, so that has been plenty of power for me, even for the woofers. With Class-D amplifiers getting more and more common, power shouldn't be a problem any more. The new JL Audio amps that have on-board DSP are 100W/ channel minimum, I think. Tweeters and midrange drivers need much less power than woofers. What I'd really like to see, but never will, is a really good quality 10W or 25W amp for small drivers.
#102
I should also say that there isn't any reason to "balance" the amount of power you have for each driver. The driver will only pull what it needs to respond to the signal sent to its amplifier channel. What you need ensure is that you have enough power for each driver (too much power available isn't a problem). So 100W for your mids and tweeters should be plenty, but you might want to have more for your woofers. After that, as you know, DSP for balance, delays, and EQ is VERY useful and powerful for tuning your sound.
#104
#105
Glad you like those new Hertz. The set you bought is more than I can afford right now. I'd really like to get a set of JL Audio C5 components. That would be a direct upgrade to the Evolutions I have now. Those drivers are pretty old, but they still sound pretty good.
You put way more mat in your trunk than I had planned on using when it's time to do my car. I had figured on both sides of the rear deck and that's it. Do you think doing the rear fender wells made a difference? I had thought the rear seat would absorb most of the noise coming from the trunk. That said, I agree with you: gotta do all four doors, inside and out. I may also get some to do the floor, eventually. Taking out the seats and center console is a lot of work.
What Noico mat did you use, the 50 mil or the 80 mil?
#106
I used the 80 mil, and must admit, it was probably overkill to do the amount in the trunk that I did. I figured it couldn’t hurt? Right? There’s definitely a difference on the outer quarter panel when you knock on it, theres no resonance. Even if it doesn’t make a difference in the sound inside, maybe it will keep the rattling at bay on the outside.
#108
Well, this is the install I wanted to do two years ago, but rushed and settled. I wound up putting the DSP and crossovers behind the trunk finishers, which required me to buy a new left finisher to replace the one I cut up. I also had two days of rewiring and I went against what I said earlier about hiding the crossovers. But after staring at the trunk for hours try to come up with a clean way to mount them, I concluded this was the best way. The amp is mounted on the underside of the rear deck, and everything else is hidden.
#110
Tommie70, that is a good looking install. Those Infinity 6x9s are huge, and so are their crossovers! You also ran impressive wire to them. Did you also mount the tweeters for the Infinities? I wish my amp board was as small as yours, it would have saved me hours and hours, as well as some head-room in the trunk. I guess there is one of the big reasons behind the class-D amplifiers. Maybe someday I'll change out my existing amps. But not today. I am really happy to be done with wiring.
How did you mount your gear, self-tapping metal screws?
#112
Hey everyone, This weekend I'll be tackling a major overhaul of my SV's sound system. I'm going to document the entire install and posing it to this thread.
The components I'm installing are;
2 - Focal PS165v1 Component systems. (Front doors, Rear deck)
1 - 12" Boston Acoustics Sub
1 - Rockford Fosgate 600W 5 channel Amp
1 - Rockford Fosgate Three Sixty .3 DSP
I'm disconnecting the factory Speakers and running heavier wire from the factory Head unit to the DSP.
This should be a good build to post as I haven't seen many pictures of the 8th Gen taken apart.
I'm not sure if I'll be posting the progress incrementally or if I'll do it all in one shot but come hell or high water, its getting done this weekend!!
Hey brother, did you use line in converter? If so how did you wire it in? Looking to throw my fosgate P3 12's and my Memphis amp in... thank you
#113
Sorry, I know, this has been dead for a while, but to anyone that's upgraded their audio system, how has the quality of calling through the car system held up, specifically how it sounds to the far-end caller? I know there are algorithms in place to help reduce echo and noise, and I'm curious if those are dynamic enough to deal with retuning/running through a DSP, or if doing so has a negative effect on call quality. Thanks for any insight!
#115
I made even more improvements over the last two years. Upgraded the amp and sub and planning more. What do y’all think of this?
https://www.crutchfield.com/p_158XAV...AV-9500ES.html
#116
I know this is an older post but have any of you had to install a high output alternator for your audio system? I'm thinking about adding a 3rd subwoofer and if I did, I'm almost certain I would have to go with a high output alternator....
Da_Shatterer
07-09-2006 06:58 PM
