Speaker Sizes
May someone list ALL the speaker sizes (and optional sizes if any) for the Bose setup. I know we have Crutchfield, but they have been know to not be accurate from time to time.
I second that request since I'm going to upgrade my SL's audio system.
Not sure why crutchfield Is so far off. I've had the whole car apart and You have many options for speakers. Now, you may have to make slight modifications for some aftermarket speakers but I had no issues installing my system.
Front doors - 6x9, 6x8, (will drop right in), 6 1/2"(made a plate to adapt) and if your really handy, I bet you could put 8" in the doors. My only problem has been sound deadening the doors. I have high end Focal speakers running 100 watts RMS in the doors and even after putting dynamat everywhere I still get a weird buzz from the skins on certain songs. Dash - 3 1/2" nothing else. I didn't install anything in the dash as it's not the best place to put a speaker. Instead, I opted to put the tweeters in the top of the doors. Rear door - they have a 3 1/2 in there, but with modifications, you'll go bigger. I don't have anything there because it's so low and not an ideal spot for a speaker. Rear deck - 6x9 6x8 will drop right in. I made a plate to adapt a 6 1/2" again if you wanted to put an 8", in there it wouldn't take much modding. https://maxima.org/forums/8th-genera...ade-build.html |
^^Thanks brother. Was not sure if the Bose was different as I seen your Non-Bose post.
^^Appreciate that and this will help others out too.
The openings are all the same regardless of the trim package. The differing sizes of speakers in the dash are because the Bose system has tweeters in the door. Sorry I didn't see that part of your question
Thank you I was always wondering what was in the dash and the read door speakers.
non-bose speakers details
Originally Posted by sdomingues
(Post 9137289)
https://cimg9.ibsrv.net/gimg/maxima....7be60e6900.png
https://cimg0.ibsrv.net/gimg/maxima....fe1d337ec4.png https://cimg1.ibsrv.net/gimg/maxima....ee216d4662.png Thanks in advance. |
I am wondering if the rear door speakers can be replaced with subwoofers?
(is this a.stupid question??) |
Any sub woofer worth a darn wouldn’t fit in any door. Since the max is a sporty grocery getter, I put a decent pre built Fosgate sub in the trunk with a quick disconnect in case I need more room. FYI, have not had to take the sub out once in two years. |
(Post 9137289)
https://cimg0.ibsrv.net/gimg/maxima....fe1d337ec4.png https://cimg1.ibsrv.net/gimg/maxima....ee216d4662.png |
are the rear 6x9's 2 or 3 way speakers? I am looking to get some more low end without installing speakers in the trunk.
(Post 9137289)
QUOTE=tentrey;9206693]are the rear 6x9's 2 or 3 way speakers? I am looking to get some more low end without installing speakers in the trunk.[/QUOTE]
From what I can tell they are just 2 way. I recently installed a pair of 12's in the trunk. With them loosening up I'm needing something to fill the upper lows with a tighter punch. I was thinking a pair of 8's in the rear deck provided it doesn't involve cutting the deck. I'm using audio control high to low converter and I already have everything there to install another amp. Just trying to figure out what would fit |
© 2024 MH Sub I, LLC dba Internet Brands
