Foward Emergency Braking(FEB) & Slip indicator lights ON
Both of these lights recently came on while I was stopped at a red light. It wasn't raining and the car was not moving. Does anyone have any suggestions on how to reset them?
The first thing I would check is the fluid level in the brake fluid reservoir. Nissan uses a combo of seemingly unrelated warning lights on braking functions to show low brake fluid level.
Some slight dropping of brake fluid level may be expected as the brake pads gradually wear, necessitating that the fluid push the pads further in order to reach the rotors. But if, after bringing the fluid level up to the full mark, you get this combo of warning lights again within the next year or so, you have a brake fluid leak, and this must be fixed. Should be under warranty.
Thanks for the advice. On my way home this morning i noticed my brake lights were also not working. Decided to check my fuses and sure enough the fuse was blown. I changed out my stop light bulbs to LED ones about a weeks ago so that was probably the issue. Warning lights are now cleared.
