My attempt at installing spoiler from Spoiler and Wing King
Old 05-24-2017, 07:18 AM
Ian B's Avatar
Will be getting spoiler in mail tomorrow and reserving spot to post how installatio attempt went or failed. My car is a 2016 Maxima S and the spoiler will be the SR version that comes color painted.
Ian B
Ian B is offline
Old 05-24-2017, 08:35 AM
sdomingues's Avatar
I just installed the OEM sport spoiler on my SR on the weekend. Couldn't be happier with how it turned out and how it looks. I was a little nervous drilling 7 holes of various sizes, but with the time spent to ensure the template was on correctly it was very easy. Plug is already in the trunk to attach the brake light and I disconnected the existing brake light in the window. Because of my tint, you can't see it anyway.
sdomingues is offline
Old 05-24-2017, 08:51 AM
gizzsdad's Avatar
Looks nice sdomingues!!
gizzsdad is offline
Old 05-24-2017, 10:25 AM
Ian B's Avatar
looks great, couple of questions for you.
1- is the brown plug inside of trunk lid where I plug in spoiler light? Did it have a male/female plug or did you splice into the cables?
2- Does unplugging deck light rear seat causes light message on your displayto come on??
Thx,
Ian B
Ian B is offline
Old 05-24-2017, 10:33 AM
sdomingues's Avatar
Thx,
Ian B
1. Yes it's the brown plug in the trunk lid. The OEM spoiler has the plug built in so no splicing needed, just plugged it in.
2. No warning lights from disconnecting the other light. They are on the same circuit and both LED so resistance should be virtually the same. And it was designed this way from the factory to have the spoiler as an option so I can't see it causing any issues.
Old 05-24-2017, 10:50 AM
Ian B's Avatar
Thx for info. Last question did you put anything or coat the holes w anything to avoid rust?
Ian B
Ian B is offline
Old 05-24-2017, 11:06 AM
sdomingues's Avatar
Ian B
No problem.
Yes absolutely, very important step!
I actually painted the bare metal on the holes and then applied a rust preventative before bolting on.
Old 05-24-2017, 05:20 PM
Ian B's Avatar
Does anyone know of the blue or white wire is the positive one. Spoiler wire does not have a connector and will have to splice into these cables to connect led third light in spoiler.
Thx,
Ian B
Attached Thumbnails My attempt at installing spoiler from Spoiler and Wing King-20170524_185937.jpg
Ian B is offline
Old 05-25-2017, 05:00 AM
Mason Hatcher's Avatar
Car looks good, but I love that Motorcycle. Details?
Mason Hatcher is offline
Old 05-25-2017, 06:26 AM
sdomingues's Avatar
Lol, thanks. Not to hijack the thread, but its a 2014 Honda CTX1300. Was only made for one year due to a lack of marketing from Honda and a lack of interest but it's a GREAT bike! Like a smaller GoldWing (and $10k less). Has the same V4 engine that was in the ST1300 for years. There are still brand new ones around for massive discounts, it's kind of crazy but anyone I've come across that has one loves it. It's big and heavy but a great touring bike, eats up miles with no effort.
It's got all LED lighting, stereo with USB and bluetooth, traction control, ABS, you name it.
Old 05-25-2017, 08:06 PM
Ian B's Avatar
Mission accomplished. Will post pics tomorrow in sunlight. Corner bolts gave me some trouble but resolved. Love the look. If you get aftermarket unit like me, the red wire from spoiler goes to the blue in the prewired connector and the black wire from the spoiler goes to the white cable in the prewired connector.
Ian B
Ian B is offline
Old 05-25-2017, 08:27 PM
Nice. I have a Victory Vision. I love it, but there is something about a V-4. I'll have to run by my local Honda dealer..
Old 05-26-2017, 05:47 AM
Ian B's Avatar
Here are the pics I took this morning. It is cloudy here today.
Ian B
Attached Thumbnails My attempt at installing spoiler from Spoiler and Wing King-20170526_064539.jpg   My attempt at installing spoiler from Spoiler and Wing King-20170526_064531.jpg
Ian B is offline
Old 05-26-2017, 02:53 PM
HoustonQX3's Avatar
Is everyone getting their spoilers from Spoiler and wing king?. I would like to add one to my White SR, but do not like the black OEM and would rather not go through the whole getting it repainted business. Wing King has the painted factory colors, and looks to be the way to go.
I am curious about the fitment overall compared to factory, and does theirs have the template as well.
They have a good sale going on and if they are GTG I would like to pick one up.
Houston
HoustonQX3 is offline
Old 05-27-2017, 02:44 PM
dentnshell's Avatar
Houston
I have a Sport style from Spoiler and Wing King. Also have a spoiler from them for my Camaro. Fit and finish is great for both... The Camaro spoiler used the factory spoiler holes.
Spoiler and wing king does not have a template.. They use a plastic piece that clips into the spoiler... you tape down to the rear deck.... remove the spoiler and drill through the plastic clip. It works great. Drilling though the clip even helps prevent your bit from walking.
I suggest a 1/8" bit and a uni-bit to enlarge the hole. The uni-bit is not needed but leaves a clean de-burred hole...
I used touch up paint on the exposed metal to help prevent rust.
Sorry I didn't take pics while I was installing.
dentnshell is offline
Old 05-27-2017, 07:33 PM
HoustonQX3's Avatar
So is the Spoiler held on by the plastic clips?. or by bolts? I guess I am not getting it..
HoustonQX3
Old 05-27-2017, 09:07 PM
dentnshell's Avatar
It is held by bolts. You use the nylon strips as guides. The fit in the bolt hole of the spoiler. They stick out from under the spoiler while you place it. You tape them down. Remove the spoiler. Drill the holes. Remove the nylon / plastic locators. Then bolt on the spoiler isn't the perfectly placed holes. I am sure there is a you tube video somewhere.
Old 05-28-2017, 06:51 AM
HoustonQX3's Avatar
Got it, I will look into ordering one then.
Old 05-28-2017, 12:01 PM
dochidalgo's Avatar
Hi, I own a SR too. Where is located the brake light plug from the rear window?
I want to disconnected it too.
Thanks for your reply.
dochidalgo is offline
Old 05-28-2017, 12:57 PM
BlakMaxiJoey's Avatar
does the trunk lid open "normally" like w/o the spoiler?
BlakMaxiJoey is offline
Old 05-28-2017, 03:19 PM
Ian B's Avatar
grab both side of brake light cover and push back and up towards rear window. That will make it pop up and out. Next, remove some of that foam gray material covering the connector. It's a ***** to remove w bare hands. You will need needle nose pliers to squeeze the clip, pull and it will release. Put the cover back on and done. If windows tinted no one will see brake part day or night. If not tinted, there is a part number for a cover without the brake light.
Ian B
Ian B is offline
Old 05-28-2017, 04:18 PM
dentnshell's Avatar
No it does not... it pops up about a 1/2" and must be lifted from there. It does stay open once lifted.
I understand that the factory spoiler "may" come with stiffer springs.
Old 05-28-2017, 09:38 PM
dochidalgo's Avatar
Ian B
Thank you Ian B.
Old 05-29-2017, 08:02 AM
Jeeper31's Avatar
Confused. My SR came with a spoiler. I thought all did.
Jeeper31 is offline
Old 05-29-2017, 09:40 AM
sdomingues's Avatar
They do not automatically, it's an option. Could be dealer installed in some cases as well.
Old 05-31-2017, 01:02 PM
HoustonQX3's Avatar
Spoiler is ordered and in route. Should have it Friday and hopefully I have time to install it Friday as well. I post up a few shots of it during the installation process.
I did talk with the guys over there at Wing King. Very good folks to deal with, and explained everything that was involved with it. Seems pretty straight forward, and shouldn't take to long.
I went with the QAB color, I thought it would go better with my Hyper gray wheels. I didn't want my SR looking like a midnight model. Gotta be different.
Houston QX3
Old 06-03-2017, 06:11 PM
HoustonQX3's Avatar
Well the spoiler showed up yesterday and installed it today in about 45 minutes. Color is spot on and finish and quality are absolutely flawless. The only hitch is you have to splice the spoilers wires into the factory connector. The two outside bolts were a little tricky, but using a long screwdriver and taping the bolts to it allow you to get them started.
The finished product looks great and I recommend using a Uni bit to have nice clean cut holes. I give Spoiler Wing and king an A++.
Here is the little screwdriver trickName:  64D4E30F-7F2F-4387-B3CC-B30CF93B8151_zpsgb63nwxg.jpg
Needs to be a fairly long screwdriverName:  9427D8E0-BD74-461B-8D2F-E807D0F94859_zpsvlh1qjg8.jpg
Finished Product
HoustonQX3
Old 06-03-2017, 07:20 PM
Ian B's Avatar
The finished product looks great and I have no I do recommend a Uni bit to have nice clean cut holes. I give Spoiler Wing and king an A++.
Finished Product
HoustonQX3
Touchdown Houston!!! Looks great congrats and welcome to our club.
Ian B
Ian B is offline
Old 06-03-2017, 08:14 PM
dentnshell's Avatar
The instructions call to use the uni but to make holes in the second layer of the trunk so that you can simply get a socket on the outer holes. I personally used my wife's fingers to get the bolt started 😄
Looks great. Congrats.
Old 06-26-2017, 12:50 PM
calabs's Avatar
Resurrecting this thread
Does the Spoiler and Wing King spoiler come with a replacement trunk weatherstrip (P/N 84830-4RA1B)? I see the OEM version does, and was curious why you would need a different weatherstrip.
The aftermarket version also doesn't come with the torsion bars. If you're interested in eventually replacing them, here are the part #s.
Trunk Lid Torsion Bar (RH) 84432-4RA0C
Trunk Lid Torsion Bar (LH) 84433-4RA0C
It looks like these are the P/Ns for the sport spoiler. The premium spoiler uses even a different set with an extension 4RA0B).
calabs is offline
Old 08-03-2017, 01:59 PM
bghouse's Avatar
Intro & Spoiler feedback/thanks...
Hello everyone,
I just wanted to introduce myself & thank all of the members for the great posts/information in the 8TH gen forum! A great forum for sure! So I traded in my 05 Altima(9+ years & 230k miles) a couple weeks ago & got my 2016 Maxima S. I was going to buy a 2017 but I was able to get mine w/ only 18k miles for $22k. AND it drove just like the 2017s I test drove and the previous owner took amazing care of it, so I couldn't pass it up. : )
Everyone's feedback on the wing king spoiler were spot on, thank you!. I got mine over the weekend & since my tinting was completed on tues, got the spoiler installed tues night. I was even happier afterwards considering when I picked up my car, the parts at the dealership quoted me $350 for the spoiler. So take that w/ the labor I saved at least $400-$500. Anyone wanting a spoiler that knows how to measure & use a drill, its not a hard mod. Like other members have said, drilling is the hardest part which is not bad at all. A special thanks to HoustonQX3 on pointing out the long screwdriver for the outer screws, glad I didn't have to drill through the second layer(inside the trunk) to tighten those up. I will post pics when I have enuff posts.
Next up, adding my subs w/ the AudioControl converter on Sat. Looking fwd to this forum & all the great info here!
Thanks again!
bghouse is offline
Old 08-18-2017, 06:30 AM
what type of nuts are holding down the end threaded studs of the spoiler to the trunk?
i have plastic things that looks funky and i think is the reason why one end is lifting up...
i'm getting annoyed how it has the frakken gap.
thank you for any reply (in advance)
Old 08-18-2017, 07:20 AM
bghouse's Avatar
There are 4 threaded points on the bottom of the spoiler where the screws go to fasten it to the trunk. no nuts.... look close at the various pics showing the bottom of the spoiler.
bghouse is offline
Old 08-20-2017, 10:46 AM
gotcha!
i guess the factory one has threaded studs, and aftermarket ones have threaded inserts on the spoiler.
another question.. does that require plastic washers on the middle holes between the spoiler and deck lid?
i am thinking i received another bad re-installation from the shop (a warranty re-work on the trunk).
Old 08-21-2017, 01:28 PM
04BlackMaxx's Avatar
Nothing like some extra rear downforce on a FWD car.
04BlackMaxx is offline
Old 02-24-2019, 11:58 AM
groovyv03's Avatar
I see this thread is from awhile ago, BUT - I'm about to put a spoiler on my 2019. To you fellas' who put one on - what did you use ( or did you use anything ) to cover the bare metal after drilling ??? I went to my local dealer to get the " Rust Preventative " P/N 999MP_9G001P, but he told me they were out, and would have to order a case of 12 !!!
Anybody ?
groovyv03 is offline
Old 02-24-2019, 11:59 AM
dentnshell's Avatar
I just used some touch up paint... actually used black, as I had it for the Camaro...
Old 02-26-2019, 11:00 AM
robtroxel's Avatar
Also try POR15 to encapsulate the bare metal if you plan on keeping this car for the long term
robtroxel is offline
Old 03-17-2019, 01:19 PM
calabs's Avatar
I'm a little confused about how to use the long screwdriver and tape trick. It's hard to tell what's going on based on the pics. Can someone give a little more detail? I'm about to install my S&WK "premium spoiler" and really would prefer not to drill through the second layer in the truck. Thanks!
calabs is offline
Old 03-23-2019, 02:54 PM
calabs's Avatar
OK, figured it out after removing the trunk cover. I had to remove the back up light to squeeze in the hole. Overall I'm happy with the install.
BTW, when removing the 3rd light assembly, I found an insert on the replacement "blank" that's made to clip the wiring into the blank. I've read some folks used electrical tape to cover the wiring harness. Not necessary if you replace the light with the blank.
calabs is offline
Quick Reply: My attempt at installing spoiler from Spoiler and Wing King
