Help painting car
Hey guys! 98.5 SE max here! New to the community. Found some reel valuable info on here so far. Great site. Seems like lots of nice peeple. Just had a quick question for u guys. My max has reely bad rust on all of the 4 rocker panels and on the floor and roof as well. Needless to say the rust is a gross color so I'm wondering what kind of paint I should use to paint over it. My girlfriend suggested acrylic which I thought was a decent idea but I was leaning more towards plasti dip. Any input/expeerince would be greatly appreciated! Thanks!
I painted my 98 last year using SW Ultra7000 Urethane paint. Urethane is more durable and will last longer than the cheaper Acrylic. Before painting you want to remove all the rust. I had to grind off sections of the quarter panels then weld on sheet metal. Also had to install new fenders. The mudflaps have kept my rocker panels in good shape.
My left side inner quarter panel where the EVAP canister hangs is about to fall off so I'll be enhancing my tools again over the next few weeks. |
Cool man thanks for the input. What type of paint brush would you reccomend? Or would it come in a spray bottle?
If you plan on painting over rust, dont even waste your time or money. The rust will bleed through and just get worse. You would have to have all the rust removed, prior to painting for any kind of real results.
Originally Posted by 98.5 SE Max
(Post 8983038)
If you don't have an air compressor then use cans for painting but it won't be as smooth. Some members have done that https://maxima.org/forums/4th-genera...n-weekend.html |
That seems like a great painting tool. Where'd you get it? I'm sure something like that could reely come in handey. Excuse me for I have no experience with paint weapons but what would something like that cost me? Money is tight with having a babey on the way!
Oh and anyone have any experience with rust removal?
The tools and paint needed to get your MAX looking new again will far exceed the cost of having an autobody shop do it.
The only cheap way of painting a vehicle yourself is using cans. Rust can be sanded off if it's just starting to eat away the metal. If it's already deep it will need to be grinded off. Whichever it is rust needs to be completely removed or it'll just bleed thru your paint like CustomLowz stated. Not to be rude but use google to get simple questions answered. |
Originally Posted by jholley
(Post 8983106)
The only cheap way of painting a vehicle yourself is using cans. Rust can be sanded off if it's just starting to eat away the metal. If it's already deep it will need to be grinded off. Whichever it is rust needs to be completely removed or it'll just bleed thru your paint like CustomLowz stated. Not to be rude but use google to get simple questions answered. I was thinking the same thing as far as cost goes.. |
Spray cans do not come in urethane, just acrylic and some have a basic form of enamel. Nothing in a spray can holds a candle to what you can spray on with a gun as far as quality is concerned. If you do not know anything about car paint don't bother with a gun/compressor setup. The learning curve is kind of steep if you haven't used one before.
For the rust, once it is sanded down/ground off, put some POR15 on. I used it on my rocker panels, works really well. Its not cheap, but worth it. |
Originally Posted by Finkle
(Post 8983581)
(Post 8983033)
drive it until you don't feel it's safe to continue driving and then just junk it. you have rusting in pretty much the entire car...it'll take A LOT of effort to fix correctly and from your replies you're not looking to get this fix properly. ANYTHING you slap on the car just buys you months/weeks...but rust will still continue. only way to get rid of rust is cut it out and weld/bolt in a new panel. |
I'm with DanNY, drive it into the ground. A 98 covered in rust but still runs...still only worth maybe $1000.
© 2024 MH Sub I, LLC dba Internet Brands
