Advance Paint and Body Work Discuss painting and body work techniques. Frame and body panel repairs, PDR, proper use of chemical and safety equipment.
Is it worth fixing
Old 08-04-2017, 10:00 AM
Mikej1's Avatar
Is it worth fixing
Need input
Mikej1 is offline
Old 08-13-2017, 05:09 PM
maximatech12's Avatar
Did it knock out the motor mount ? If the shock mount is knocked out id say junk it to make a statement!
Its fixable. If you look up the body parts youll see the subframe and all are on the market.
You could carefully remove the panels with a spot weld bit then weld the replacement panels in.
If you pull the engine youd probably get over $200 in scrap aluminum.
Dupli color sells a Nissan pebble beige color and sunlit sand color paint that might match up pretty good!
maximatech12 is offline
michaelliv
10-01-2016 05:20 AM
Stuart Ramsey
08-25-2013 06:41 PM
S1cTech
30
10-26-2011 01:37 PM
SuperBlackSE
50
10-21-2005 01:36 PM
mjwitte99
04-23-2004 06:37 PM
Quick Reply: Is it worth fixing
