Any ideas for front drop only....
#44
Originally Posted by PENROSE2006
I would like to make a thread too....or at least do a search!!
Whats up?? This is strange
#46
Nations 1st 6th Gen Turbo
Trust me, I read the "Shimmy Post" cover to cover. I didn't have the shimmy with the stock wheels/tires though. I didn't get it until I put the new wheels/tires on.
I am using the hubcentric rings, did 4 remounts and balances (2 of them were road-force balanced). They all said that the wheels were fine (run-out was within specs). The steering wheel shook at 55-60mph....anything above or below 55-60 and it is smooth as $hit.
Tire-Rack.com sent me 2 new tires and I had these mounted yesterday. Now the steering wheel shimmy's at 60-65mph and my seat shakes now too....it's worse!
#48
Originally Posted by madmik
I concur. I drove in Mtl early April and had to slow down to 30-40 kmh often to make the ride bearable. It was like driving a Vette.
Since you ride on 17” in the winter (1/2” lower), the first piece of ice may cause havoc at the front if you lower it more. Not sure if they make coilover yet for the Max but those would allow you to raise the front for winter.
Best to Villeneuve on the 25th. But I think Alonso is unbeatable this year.
Alonso is unbeatable and Schumi has shown us what a spoiled little brat he can be! I think he's just a poor sport and doesn't like being in the loser seat now.
On another note, I noticed that you're from VA. I have been up and down VA and man you have one beautiful state there! Eh? Nicest roads I've ever had the pleasure to drive on...till you reach Baltimore HE HE!
I used to rep a company in Sterling and have flown in and out of Dulles and Reagan. One of my best friends lives in Fairfax and I have driven on Chain bridge rd. Man that's nice! He used to live in Falls Church...nice too! Been a few times to Norfolk and V. Beach ....nice people nice places! Come back to Montreal now that the weather is beautiful. We have a fleet of special automatic trucks that repair pot holes with gluey black ashphalt gunk...LOL! And it works! Within one month most of them are done (90%). We have the Jazz festival starting at the end of this month for 10 days. It's a multi street fest with many outdoor free venues and beer, liquor and food are served outside in a controlled perimeter. This is one of the best in the world and is our summer claim to fame! All welcome!
Sorry to go off topic...
#49
Another concern is how much your weight transfer characteristics will be affected with only a front drop (assuming a stiffer aftermarket spring). Differing driving styles require different suspension setups, but usually with a floating rear end and stiff front springs is not recommended.
Remember, this forum isn't for looks. Its for performance.
Another reason to upgrade the shocks the same time you change springs is that the stock OEM shocks do not have the rebound and dampening cabability of aftermarket shocks combined with a stiffer spring.
#50
I have the Progress springs ready to install on my 06, and I'd like to replace the struts and shocks as recommended. Are the KYB GR2s still the only available option? I'm not sure I'd like them. I had those on a 93 Altima, and the ride was too stiff and bumpy for me.
#52
Originally Posted by Larrio Motors
I believe the GR2's are non-adjustable(?) I'm not familiar with them. I'd recommend going with something that offers dampening adjustability
As far as the end result of lowering only the front is concerned, one effect is that you give away more front grip than if you lower the front and rear equally, based on two separate effects. Another is that outside shoulder wear rates can be expected to get worse. I'm not seeing any real benefits, and "tire gap" isn't visible from the driver's seat.
Norm
#57
I just received my Progress springs and am waiting on my GR2's. I will lower the front first and will let you know the difference in handling. My 05 has 13k miles. Before I bought the MAX, I tried an 05 Altima SER and decided that the suspension was way to stiff for my city driving. That is why I picked Progress and KYB. If I am wrong, I will just get the Illumina when they become available. I am also planning to get a Y-pipe and since its a tad lower than OEM, I didn't want to lower the front too much.
#59
It doesnt sound like hes interested in the handling benefits of getting aftermarket springs.
I know this is usually considered type talk but the stock springs are linear, so cutting a coil off them would not effect the spring rate. Also the stock springs up front are quite tall usually several inches taller than aftermarket springs. Thus if you did reach a case where you bottom the car out, you would be bottoming the shock out (aka the shock reaching full compression state) before fully compressing the spring and bottoming the car out that way. If that makes any sense.
So I dont really see why it couldent be done. Just dont expect the car to handle any better. Your playing with suspension geometry here. Good news is its a free mod and if you screw it up you can buy used stock springs for next to nothing on the org.
#60
Originally Posted by sciff5
. . . but the stock springs are linear, so cutting a coil off them would not effect the spring rate.
[SpringRate] = { [ShearModulus] * [WireDiameter]^4 } / { 8 * [NumberOfActiveCoils] * [MeanCoilDiameter]^3 }
Cut one active coil out of a 300 lb/in 6 active coil spring and you can expect it to then be a 360 lb/in spring.
What cutting an active coil from a linear spring doesn't do is change the progression.
You'd have to cut off an inactive coil (one that is already "bottomed out" against its neighboring coil) to have no rate change.
Norm
#61
Originally Posted by bluestreakgts
Whats the lowest spring for the 4th gen
Provide it, in detail to the best of your ability, and I will do my best to help. Take your time.
kingw323
20
10-21-2015 08:36 AM
Maxima_Joe
08-27-2015 12:01 AM
BobMax
08-15-2015 12:35 PM
